Question about Ricoh SFX2000M Plain Paper Laser Fax
Ricoh SFX2000M that doesn't print images; just gray stripes
I tried to receive a fax yesterday and the machine received but only printed gray stripes, nothing clear. So, I tried to make a copy and got the same thing. No image would come through.
blueydfox
  • 13 Answers
SOURCE: Ricoh 3900 L Fax Machine - Bottom Catch Trays (for receiving faxes)
Here the numbers.
H545 2130 Copy Tray 1
H545 2131 Copy Tray Extension
Posted on May 02, 2008
EmmettPinger
  • 63 Answers
SOURCE: Fax Print Sideways
problem has to be on the sending side..
Posted on May 01, 2009
EmmettPinger
  • 63 Answers
SOURCE: Clear a Ricoh Fax 2000G Memory
    1. If your documents have already been scanned into memory:
    2. touch the [Change/Stop TX File] key
    • check that the [Stop Transmission] key is selected
    • touch the file that you want to stop, then touch the [Stop Transmission] key in the confirmation dialog box
    • touch [Exit] to return to the Fax Mode display
    1. If your documents are being transmitted:
    2. press the red [Clear/Stop] key
Posted on May 05, 2009
  • 398 Answers
SOURCE: Ricoh fax 2050L displays:
Thru user tools check what size is said to be in the fax and if it has the optional tray that size too. -Carl
Posted on Jul 07, 2009
e-Guru
  • 3917 Answers
SOURCE: replaced the power supply/controller pca
If the tonner has gone old please take it out and shake if for atleast 2 to 3 minutes before putting it back and takng printouts. The issue would resolve but its a temporariy fix as you would require to change the tonner .
Let us know if you need further clarification.
Thanks
Posted on Dec 30, 2009
How do I stop printing from RICOH 1515 from fax
You might have this fixed already. If not, you may help me help you by saying what happens. Does the machine show a jam because paper is a different length than programmed into machine? This may cause machine to never "complete" printing your received fax. I will see if anything else comes to me.
Sep 20, 2014 | Ricoh Aficio 1515 Black and White Copier
Brother fax machine MFC 495 CW won't print a received fax
Hello sir; would you try on another phone jack if still have same problem then replace phone wire.
Nov 01, 2012 | Brother MFC-495cw Color Inkjet All-in-One...
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
Our Ricoh 1800l has stopped recieving faxes how do I fix this?
our Ricoh 1800l has stopped recieving faxes how do I fix this
Feb 15, 2011 | Ricoh SFX2000M Plain Paper Laser Fax
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
Fax not received
No, just the fax phone number.
Mar 09, 2009 | Ricoh 3310Le Fax Machine, FAX3310Le...
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
Printing same page
try this make sure that receive reduction is switched on. You could load the paper tray up and just let it print as may have been a communication problem from RTI memory. Being Richo machine you should be able to reset the memory but this will get rid of all your stored numbers. But it will reset the machine so if you have a corrupted memory issue this will get rid of it.
Hope this helps you
Thanks J
Sep 11, 2007 | Ricoh 3310LE Plain Paper Laser Fax
Ricoh SFX2000M Plain Paper Laser Fax Logo
62 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
