Question about Savin Office Equipment & Supplies
Jam code 19 savin 9025
Jams when making duplex copies
SOURCE: Error Code 000061-0001
Error code for 0061-0001
Main cause : The laser shutter is faulty. The laser unit is faulty. The potential measurement PCB is faulty. The DC controller PCB is faulty.
Mode of detection : 0001- As the result of potential control, the drum surface potential (VL2) of the white background is about 200 V (generating solid black images.)
Posted on Dec 18, 2007
  • 33 Answers
SOURCE: Panasonic DP 2500 J81-J82 paper jam
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
Posted on Mar 05, 2008
SOURCE: Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Posted on Mar 31, 2008
Cogz
  • 1326 Answers
SOURCE: savin copier 9400d error code 542
I believe that code has to do with the fixing unit. Try to reset it, press the yellow clear botton once then the #"s 1-0-7 then the red stop botton. The display should change.... turn the copier off then back on.. It should reset the code for you.... Just a question dose it have a finisher on it? If it dose have you tried to unplug the finisher with the power off then turn it back on...Is the code gone..if so you have a problem with the finisher... I work on to many different brands.... Good Luck
Posted on Jan 31, 2009
goalie39
  • 469 Answers
SOURCE: Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Posted on Apr 28, 2009
How do I fix paper jams for Savin 4018d
If it jams on the way out every copy the the exit switch is out of position or broken, if not then sep pad p/n B0392711. -Carl
Jan 21, 2015 | Savin Office Equipment & Supplies
Cannot copy two side.paper always jam
Are you sure there is not something blocking the paper going inot the duplexer. I've had one of the fuser separation claws fall off and block the path. Now if that is not the case then check to make sure some of the sensor arms don't have paper cuts in them. This will cause an intermittent delay jam. Jam codes in service mode will also help.
Jun 17, 2011 | Canon NP 6050 Copier
Duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Apr 01, 2010 | Minolta DiALTA Di183 Copier
I have a Savin 9400 copy machine. It will not print 2 sided copies. Everytime I try to print a 2 sided copy, it jams after it prints the first side and before it prints the second side.
Hello sir; You need to clean the reverse roller with alcohal, if you don't know which one is reverse roller then you can clean up all the roller in duplex unit.
Aug 28, 2009 | Savin Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Mar 06, 2009 | Panasonic Workio DP-3530 Copier
False jamming at duplex unit
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Feb 21, 2009 | Canon NP 6050 Copier
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Paper Jam E54
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
http://checkitright.spruz.net/main.asp?page=dp&dis=592197
Nov 17, 2007 | Toshiba e-Studio65 Copier
32 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
