Question about Lands Phones
No sound in my voip phone
Hi, I have an Air Top Dual Phone VOIP/DECT Model ED-4050V. It was working fine up til yesterday. Occasionally I'd have phone conversations where the sound was broken or delayed. Now I can't get any sound at all. My computer desktop speakers are disconnected. I've changed the sound setting in the control panel which was what I was doing in the past. Also checked the batteries. I'm able to call my cell phone but I don't hear it ring on the voip phone. Same with the house phone. I use Yahoo for my voip calls.
Any help is much appreciated.
alannab52@yahoo.com
  • 201 Answers
SOURCE: VOIP will no ring
Just "VOIP Phone" is not enough information to help you. There are many hundreds of different phones, connections, & setups you could have. What type of phone (make, model number)? Is this a VOIP phone connected through a home network, cable modem etc.. for home use? Is it a single line phone connected to a VOIP box connected to your cable modem? Is it a VOIP phone system connected to regular copper phone lines? Are you using a VOIP phone at home connected to a VOIP phone system at work?
Posted on Nov 18, 2007
mattozan
  • 555 Answers
SOURCE: I have an AT&T Merlin
A manual for your unit can be found here.
This guy was built way before VOIP was ever a consideration. It won't support VOIP switching natively.
You would need a VOIP gateway to do the conversion between digital (your VOIP lines) and analog (your Merlin lines).
Posted on Feb 28, 2008
SOURCE: Phone will not ring
I have the same problem for this hpone. The phone can answer and make call but not ring, of couse the answer machine function does not work. I used Rogers home phone and now the Linksys voip adaptor. But the phone works well with landline. I think the ring votage may not enough to ring the phone. Anyone get the solution?
Jack
Posted on Apr 24, 2008
  • 264 Answers
SOURCE: speedstream 6520 enabling voip connection to yahoo voice
You should log on to the GUI mode of the Router. There you should find the settings for the VOIP.
Also check this link and you should get the infor specific to the Yahoo VOIP
http://voice.yahoo.com/
Posted on Apr 29, 2008
SOURCE: philips voip 123
the reset seems to have fixed the problem for me as well.
Posted on May 07, 2008
DECT 6.0 home phone doesn't ring after switching to u-verse/voip
Have you tried to plug the base unit into a different phone jack to see if it might just be that outlet. You may have a short in that particular phone jack or a loose wire there.
Good Luck.....
Dec 29, 2009 | Philips DECT 6.0 Phone with VOIP
Hello,I have connected a linksys voip
Hello dandashi77,
I am using a Panasonic DECT 6.0 Series cordless phone. However, the VIATalk.com VOIP Services uses a LinkSys PAP2 adapter which can work with any type of phone. A Broadband connection is required to use the VIATalk.com VOIP service. Setup is very simple and the instructions areeasy to follow. Just a few simple things to do.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
No Dial tone on my DECT 2882
Everything is fine now.  Turns out the problem was not with the phone at all, but somewhere in the tangle of connections from our high speed internet modem to the router to the VOIP device.  Resetting all three of these fixed it.
Jun 11, 2009 | Uniden DECT 6.0 Cordless Telephone...
Philips 321 voip phone, problem calling out with skype
some things to consider
Have you topped up credit on skype?
dialing code correct uk +44, mobile number +447958475236 ect?
if this does not work look in your manual and reset your phone and try again
regards
Muzzi_123
Apr 04, 2009 | Philips DECT VOIP-321 cordless telephone
Change time zone Dect 6.0 Dual handset
Singerjaxfl, I used to have the same problem with my Vtech DECT 6.0 phone. I solved it by changing the system time on my VOIP Adapter.
In order to do that, you need to (1) know the IP address of your VOIP Adapter (the manual should have it, or ask its manufacturer), and (2) have the Admin authority (again, the manual or manufacturer) to change system time.
Mar 16, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our own.phone.
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Feb 16, 2009 | Philips VOIP8411B/37 IP Phone
Contact list not available on voip321 handset
Using Skype 3.8.0.180
Go to Menu-Tools-Options-Advanced and give your voip321 access to skype application.
I had the same problem, solved when I allowed the skype phone to access skype.
Cheers
Mar 23, 2008 | Philips DECT VOIP-321 cordless telephone
VOIP will no ring
Nov 17, 2007 | Lands Phones
Olympia VOIP Skype + DECT Phone
need Olympia PBNext OL2112 manual , can't set the clock ..thanks
Oct 19, 2007 | Olympia Lands Phones
Lands Phones Logo
204 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
