Question about Canon imageRUNNER C3200 Color Printer
Canon C3200 / C1 Rip
Hi Canonman1,
In following up to this previous post: https://www.fixya.com/secure/support/t668887-canon_c3200
We tried installing the C1 RIP. It is currently supplied with a power cord and a cable which plugs into the Video port. When we installed the C1, there was no port on the printer itself to accommodate the connection of the video cable. The one the scanner body plugs into is slightly smaller so this cable will not work. Another post I came across mentioned someone who had the C1 video plugged into a card beneath the network port on the 3200. There are no expansion cards on our printer under the network port. So, there is no place to even plug the rip into.
Our next step was to plug our network cable into the network port on the C1 where the LEDs are. We then ran both regular ethernet and crossover cable between the remaining network port on the C1 (next to the video port) and the network port on the 3200. (Our thinking is that the video cable may not be necessary).
Once the cables were connected, we powered up the rip. There was a problem. The power (fan and LEDs) come on for a split second then the entire C1 rip powers off. Each time we power cycle the rip, it does the same thing, everything on for a second, then it all shuts off. We disconnected all the cables (video and network) and power cycled, it is still displaying the same symptoms.
We sent the unit back to the place we purchased it. They claim they powered it up and ran it successfully on a 3200 unit they had in house and even printed out a Info sheet from the rip itself, sent the unit and the printout back to us. We powered it up again... same thing happened. Obviously, the printout displays the serial number for the 3200 they had it hooked up to but not the rip, so I don't know if it was really this rip that was connected.
In either case, we have a C1 rip that is not working. We have no technical manual to test the power leads to see if the voltages are correct in the C1 and we are left to believe that perhaps the video cable in some way is a checksum to make sure it is connected to a 3200 in order to then power up.
(One final note: we also set the printer to Int-face 3, for kicks - this was unsuccessful at establishing any power up or connection with the rip).
If you have any ideas or solutions, I really appreciate your help.
Thank you!
Jeremy Swanson
jeremy@creativemk.com
(800) 605-4280
  • 32 Answers
SOURCE: okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Posted on Feb 12, 2008
flsts
  • 10 Answers
SOURCE: Scan error C3200
C3200 indicates a problem with the exposure lamp. You can try to clean the optics and check the lamp. It may need parts if cleaning does not fix it.
Posted on Feb 27, 2008
SOURCE: Canon MP830 power outage while printing
My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
To might great relief my MP830 powered up and is working just fine.
Posted on Jul 07, 2008
SOURCE: IBM Laser Printer 4537-N01 900.43 service RIP software
I rebooted with the network cable out.. Once up again I plugged it in and off it went.
Posted on Jul 23, 2008
  • 118 Answers
SOURCE: canon imagerunner Ir c3200 total reset
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Posted on Jun 22, 2009
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Oct 08, 2015 | Canon Office Equipment & Supplies
Canon ir c3200 error code e0100-110
get manual here
http://www.scribd.com/doc/61327440/Canon-Irc3200-Service-Manual
Mar 23, 2014 | Canon iR C3200-C1 PS Ver1.0
Will windows 7 64 bit work with Canon iR C3200-C1 PS Ver1.0
you will have to check to see if you can get a driver for the canon to run on windows 7 64 bit
Aug 02, 2011 | Canon iR C3200-C1 PS Ver1.0
Connect device to laptop
you need to be able to configure your lap printing drivers to print to the ip adress of the copier.... does the copier have a rip or is it stand alone
Apr 19, 2010 | Canon imageRUNNER C3200 Copier
What is included in the Canon Network Multi-PDL Printer Kit-C1 , 6895A010AA for IR2200, IR2800, IR3300
The N (network) boot ROM and the NIC. You will need to get a tech to install these and update the firmware on the copier.
Feb 16, 2010 | Canon imageRUNNER C3200 Copier
ImagePass-C1 Not Printing the Pantone Colors
you need a set of kodak cards to run full colour set up on your fiery print controller then you just follow the intructions
Oct 29, 2009 | Canon imageRUNNER C3200 Copier
Canon IR c3200 - CAn't dNetwork Scanning (Simple - Shared Folder)
Hi,ok you have to load the clolor network scangear exe file.If the scangear is installed,click on discoveron the color network scangear tool.It will detect the machine,select the machine.
Then it will be ready to scan into word or other programs.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
Factory Defaults IR C3200
you need turn rui on if you do not have a c1 rip it is under add function then system setting then network setting if you are using the c1 you need to do it under the rip set up
Dec 23, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Color Printer Logo
96 people viewed this question
old marine
old marine
