Question about Lincoln Measuring Tools & Sensors
Engine removal on a lincoln portable welder w/ 16 hp briggs and stratton motor
SOURCE: Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Posted on Aug 16, 2009
  • 24 Answers
SOURCE: ENGINE REMOVAL ON A LINCOLN PORTABLE WELDER, WITH
The collar is a slip ring, you remove the engine and rotor together and then remove the rotor from the engine.
Posted on Sep 18, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a 18 hp briggs and stratton engine that will not start
A few more things to check.
1. The oil level. If the oil level is low the oil level sensor will ground the ignition.
2. Check the wiring from the seat safety switch to make sure it is connected.
3. Follow the black wires from the ignition control module to make sure none of them are chaffing and do not have a chassis ground.
If you still have problems disconnect ONE lead from the oil level sensor and see if you have spark. Most of the time these oil level sensors are the common failure.
Kelly
Posted on Apr 30, 2010
SOURCE: briggs & Stratton 18 hp v-twin engine surges
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Posted on Nov 06, 2010
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Motor won't run unless choke is on. It is a 16 hp v twin.
check breather to make sure it is clean and clean the carburator
Apr 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
Aug 19, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Oil in aircleaner and smokes
You need too drain your oil and make sure you put the proper amount back in too much and it will shoot oil and smoke...
May 09, 2009 | Briggs and Stratton 073001 2" Portable Gas...
I have a potable generator that will not turn off.it's a 16.5 briggs vanguard v-twin motor.i replaced the coils and the diode wiring assembly.i fill the diode assembly might be backwards.is that possible?
Are you saying the engine will not turn off? The engine shut down uses a ground on the ignition circuit to shut down. This kills the circuit that provides the spark for the engine to run. See if you can trace the circuit for the shut down and check the ground connection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Mar 09, 2009 | Briggs & Stratton 8,000 Watt 16 Hp...
Measuring Tools & Sensors Logo
43 people viewed this question
Top Lincoln Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Lincoln Measuring Tool and Sensor Expert? Answer questions, earn points and help others
