Question about JVC TH-A5 System
System not functioning
The power comes on but the DVD tray does not open when activated and neither does not the FM/AM radio. Please help. Tks.
    President:
  • 3,130 Answers
If the radio or the other functions dont work, then theres a system control problem or a power supply problem. Depending on nhow old this unit is, you may want to consider upgrading as this unit will have to go into a repair shop to trouble shoot. If you have had some solid state training or experience, and have a schematic and a multi meter its a good possibility you can find the problem.. Good Luck
Posted on Aug 06, 2006
Jvc th-a5 dvd door stuck
Posted on Oct 01, 2008
SOURCE:
How do you put a cd in
Kylie, if there is a CD tray press the eject button and put CD in tray, push tray in easy to load. If no CD tray insert CD into CD slot and push gently to load. Some have a lid on top that you simply open with your finger then load CD. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JCR 310 AM FM Stereo Dual Alarm Clock Radio with CD Player
Christmas Presents 2013 RCA RP5605 AM FM CD Clock Radio
Magnavox alarm clock radio CD player
Problems With My GE General Electric 7 4901A CD Player AM FM Clock Radio
Jun 17, 2016 | Audio Players & Recorders
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
Dvd tray will not stay closed. opens and shuts randomly
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.9acead3.jpg
May 12, 2009 | Televison & Video
Advent DVD player in vehicle - can't get sound through speakers
I just solved this problem on my Ford Edge 2010. Start the dvd. Hit the FM button on the remote. It will pop up an FM radio frequency in the top left corner of the screen. For example, ours is 88.7. Tune the car radio to that frequency and the sound should come through the speakers. Hope it works for you.
Mar 24, 2009 | Sony MV-900SDS Car DVD Player
DVD trays out - Panasonic SA-PM39D
there are very tricky mechanical devices that detect when the trays are closed and in what position they are in
A gear or mechanical piece is not in correct order or not functioning properly and will need intense studying to determine which position they all should be in at door closed , laser mech. position , standby position
can you upload a photo of the inside of the cd mechanism?
Oct 18, 2008 | Panasonic SC-DK10 System
RCA RTD215 MANUAL FUNTIONS WILL NOT WORK
Looks like the remote is faulty, a replacement remote may fix it.
Aug 29, 2008 | RCA RTD210 System
Dvd tray won't open
unplug the power to reset it.
Jul 07, 2008 | Televison & Video
Samsung dvd-r135
The Disc Tray Will Not Open And/Or There Is A Disc Stuck In The Player. spacer.gif Some DVD Players manufactured prior to 2003 have a Dealer Lock or Child Lock function. This will prevent the panel buttons from operating.
This function is activated by pressing the STOP button on the front panel
and the POWER button on the remote control simultaneously for four seconds in the power on state. Repeating this sequence releases the dealer lock. When the dealer lock in activated, DEALER LOCK ON or DEALER LOCK OFF scrolls on the display.
If this does not resolve your problem there may be an error with in the player. To resolve this try the following these steps:
  1. Unplug the DVD player from the electrical outlet and leave it unplugged for thirty seconds.
  2. Plug the DVD player back in to the electrical outlet, but do not turn the DVD player on.
  3. With the DVD player off, press the [Open/Close] button on the front of the DVD player. The home theater should power on when you press the [Open/Close] button and eject the tray.
The second option worked for me...
Apr 12, 2008 | Samsung DVD-R135
JVC TH-A5 System Logo
131 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
