Question about Dryers
Whirlpool estate model NUMBER TEDS840JQ2
Broken drum belt
revamos
  • 16 Answers
SOURCE: I have a Whirlpool dryer
one of two ways you have a two part front panel the lower part take a flat head screw driver to each side at the top of it and pop it open or at teh top were the clean vent filter is the are two screws remove and at front of dryer pop top open upwards then there are two screws at front to hold panel up
Posted on Apr 19, 2008
aborcass
  • 2651 Answers
SOURCE: 2003 whirlpool dryer problems
full size free standing whirlpool dryer???? part number 341241, on a scale 1-10 it might be a 3 for a first timer, the package i belive even comes with direction on installing
Posted on May 13, 2008
captaynkyrk
  • 170 Answers
SOURCE: estate tgds840jq1 drum
Here's a link for your model that gives you an exploded diagram of it: http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=TGDS840JQ1&mfgModelNum=&fkMfgID=3. it should help you take it apart. Good luck!
Posted on Jul 14, 2008
jsrock516
  • 5911 Answers
SOURCE: CANT FIND MODEL OR SERIAL NUMBER ON DRYER
There should be a nameplate along the door opening. This is normally where Whirpool puts their information. Just open the door and look along the door or door frame opening. The nameplate data can also be located along the back of the operator console on some models. Let me know if you still can't find it. I hope this helps.
Posted on Nov 11, 2008
jsrock516
  • 5911 Answers
SOURCE: The belt on my Whirlpool Dryer mod. TEDS840JQ2
You can replace the dryer belt by performing the following steps:
1. UNPLUG the dryer.
2. Open the lint screen cover on the top of the washer and remove the screen.
3. With the screen removed, locate the two screws under the lint screen cover and remove. Use care not to drop them down the exhaust chute.
4. With the screws removed, the top panel can be pulled towards you slightly and lifted up.
5. Either prop the top panel up or rest on one of your shoulders as you locate the door switch plug and disconnect.
6. With the top still up, locate the two screws holding the front panel in place. There is one on each side bolting the front panel to the side panels.
7. With the screws removed and door switch unplugged, grab the front panel at the top center and lift up to remove from the mounting clips at the bottom.
8. With the front panel removed, you should now have ready access to the drum and drive belt. You can lower the top panel and rest it on top of the dryer casing for now.
9. Remove the old belt and loop the new belt over the drum with the ridges facing the drum.
10. Reroute the belt around the idler pulley and drive motor shaft. NOTE: It is common for the idler pulley to come loose when the belt breaks. You may find it lying on the bottom of the dryer cabinet. To reinstall, hold the pulley in your hands with the wheel to your left. Insert the cleated end of the pulley in the grooves in the bottom of the dryer case and push the wheel with your left hand to the right to keep a slight tension on the pulley. Now feed the drive belt UNDER the wheel and over the drive motor shaft. If done correctly, the belt tension will keep the idler pulley in place. If confused, refer to repairclinic.com and click on the "Repair Help" link. On the following page look for the "Dryer Belt Diagrams" link under the Special Features section. The diagram you will need is diagram H.
11. Once the belt is in place, reinstall the front panel by making sure it is inserted on the two small black mounting clips at the bottom two edges, first. Once inserted, hold the panel in place with your knee and install the two mounting bolts to secure the panel.
12. Reconnect the door switch plug. If you forget, the dryer will not run.
13. Lower the top panel back in place and install the two screws under the lint screen cover. DONE.
You may feel like a contortionist with some of the these steps. You can perform this alone, but its easier if you have assistance.
If you get stuck along the way, or have questions, please let me know. I hope this helps you.
PS Refer to appliancepartpros.com and type in your model number for some excellent exploded views of your dryer. This may help you in locating parts and how to reassemble.
Posted on Jun 11, 2009
Dryer will run and heat but will not turn
It sounds like your drive belt might be broken you can get a new one if you go to www.repairclinic.com enter in your model number and it should cost around 9$ the other possibility is the tension pulley or if it doesn't sound like your motor is running but most likely the drive belt .
Nov 24, 2012 | Estate by Whirlpool EED4400WQ Estate 29in...
The switch on the lid that lets the drum spin is broken. how do i get to it? where do i find the model number? the name on the unit is estate.
model number would be found by lifting the lid and looking towards the back of the machine inside the lip here is also a video of how to replace the lid switch this video is of a whirlpool but an estate is made by whirlpool and the repair is exactly the same click this link to watch the video http://www.youtube.com/user/RepairClinic?v=MFsvLiuTniU&feature=pyv&ad=5454771221&kw=washer%20switch&gclid=CLvT4_CuwKgCFYXc4Aodl3k-rA
if you have any further questions please message me back and please also remember to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations Thanks again Rick
Apr 28, 2011 | Whirlpool Washing Machines
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
My Estate gas dryer will not tumble. What should I look for to repair? Model number is TGDS740PQ1
Most dryers are driven by a belt around the drum, motor and tention pulley. Check the belt.
Jul 14, 2009 | Whirlpool LER5636P Electric Dryer
Belt on my Whirlpool dryer, Model # LG5201XTWO is broken.
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Estate TEDS840JQ Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
May 12, 2008 | Dryers
Dryers Logo
Top Dryers Experts
