Question about Targus Computers & Internet
Need instructions for targus amw 57 wireless mouse
Johnboy36
  • 77 Answers
SOURCE: HOW TO SET UP AND USE TARGUS WIRELESS COMPUTER MOUSE
I assume this is a wireless mouse, Is there a similar button on the reciever? press this at the same time as pressing the one on your mouse
Posted on Mar 06, 2008
SOURCE: I have the Targus wireless mouse amw10us. It just
Mine did the same thing, so I took it apart. The flip hinge in the receiver wore through the wire running between the plug & the little board inside. I'm shopping for a new mouse.
Posted on Aug 01, 2009
SOURCE: targus wireless mouse not working
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
Posted on Sep 01, 2008
SOURCE: targus pawm10 mouse doesn't work
if you have a problems whit this muse onli pick the balck reset button from down RF USB and mause have 1 too pick too and the ligths flashing 3 sec and ready to used it cyaa srry 4 my eng
Posted on Oct 02, 2009
SOURCE: targus wireless mouse amw05 does not work, I put
The reciever is poorly designed. The green and/or white wires are probably broken on the inside.(pins 2 and 3)
Posted on Jun 13, 2010
Anyone have drivers for this mouse?
Go here
http://targus.com/us/driver_support
The product name is:
Targus Wireless Laser Stow-N-Go Laptop Mouse : AMW15US-01
There should not be a need for a driver.
May 20, 2015 | Targus AMW15US Mouse
I am trying to use it on Windows Vista and on the other computer on Windows 7. In both cases the systems give an error - the devise is unknown. The result is -the mouse is not working. Are there special...
Try reinstalling the drivers that came with the mouse. They are below. http://www.targus.com/us/downloads/amw-amu_tiltsoftware_v4_1.exe
The manual could also help http://www.targus.com/us/downloads/amw15_ug.pdf
Sep 09, 2010 | Targus AMW15US Mouse
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
How do i install a targus mouse
Depending on your OS, just use the software provided and then place the batteries in the device and connect it as directed.
Sep 21, 2009 | Targus Wireless Optical Notebook Mouse...
Describe your Targus Wireless Keypad &
there is no need of softwere for both. im now using logitech brand. But we need to set progrram in control pannel. we should use battery in mouse and key bord. To contact usb senser. thanks ( nepal)
Jul 11, 2009 | Targus Wireless Keypad/Mouse PAKP003U
How do I install the battery on a Targus PAWM004 wireless mouse? There is no apparent way to remove the cover from the mouse and removing the small screw does not release the cover of the mouse. Thanks
yo dude just slide the silver cover back its tight but does come off, instructions available on their website, by the way you dont need a driver for xp will pnp
Mar 21, 2009 | Targus PAWM001U Mouse
Targus wireless mouse not working
Aug 24, 2008 | Targus Wireless Optical Notebook Mouse...
Mar 06, 2008 | Targus AMU18US Mouse
Computers & Internet Logo
255 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
Josh Whitehead
Josh Whitehead
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
