Question about Brother Office Equipment & Supplies
Error negotiating capabilities twain driver
I get the message "error negotiating capabilities twain driver" when trying to scan an image at the highest resolution using Corel PhotoPaint. Is there a way to increase it's capabilities so I can scan at higher resolutions?
SOURCE: Scanning high Quality images
Two questions for you to help with a solution:
1. What operating system are you using?
2. Are you able to scan an image of any size (even a postage stamp size) at 2400 dpi? (Try setting the scanner to just scan a small section of a larger image as a test for this.)
If you can scan smaller size images at 2400 dpi then it is possible to scan the image in two (or more) parts (upper half / lower half) and then re-assemble the image in an editing program.
Posted on Dec 19, 2007
iqbal_del
  • 655 Answers
SOURCE: We need to set the
try to set from Start-> Control Panel-> Scanners -> Properties.
Then set the values and select ok/Apply to save the value.
  • Pleae close if any window open for scan before making the above changes.
Post your feed-back.
Thanks
Iqbal
Posted on May 06, 2008
  • 74 Answers
SOURCE: How to change to a higher resolution on a mfc-240c
Hi tammy, you can either use the Windows printer driver which will allow you to set scanning resolution up to 1200 dpi which you can access through a program like Photoshop (File--Import) or the Brother Scanner Utility to go up to 19200 dpi resolution. If for some reason you don't have the scanner utility on your computer, you may have to install it from the disc that came with MFC-240. If you need further help let me know.
Posted on Oct 23, 2008
SOURCE: Change Scan to Memory Resolution
paper is jamming while trying to print - i want to see if any paper is jammed but cannot open to see in there.
Posted on Mar 01, 2009
copper7op
  • 30 Answers
SOURCE: How to change the default scan resolution on M20i?
You need to go to the printers webpage from your Web Browser http://192.168.1.100 or something like that. Then, go into Properties tab, and then the Services Dropdown. Under that, go into Email Settings and then Email Setup. Change your DPI to as high as 600dpi, then scroll to the bottom and hit save. You'll be prompted for a password which is either Admin / 1111 or 11111 / x-admin
Posted on May 01, 2009
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
My HP Colour LaserJet CM1312 has refused to print a one page document which has a few boxes on it with coloured pictures and writing. This has never been a problem on any other printer. It printed out an...
If you edit the photos and save them at a lower resolution, then put the lower resolution photos into the document, that's the quick fix.
A program such as photoshop or corel photopaint are able to do this quite easily. In corel for instance you simply resave the photo as a jpeg, and it'll ask the resolution/quality etc. and you can reduce the resolution usually quite a bit before you lose any quality in the printout.
The other solution is to upgrade the printer's memory.
Inkjet printers usually will not have this issue because they don't need to form the complete page in memory before printing like a laser printer does. An injet's image is formed line by line in the print driver and then streamed to the printer, so the printer's ram doesn't have to take the whole page at once.
Mar 25, 2011 | HP LaserJet CM1312 All-In-One Printer
Have just been given a canoscan lide 20, i have downloaded the drivers and the canoscan toolbox but now im lost. When I push the SCAN button I get a message that asks me to 'specify the program where the...
Whichever program you wish.
MSPAINT comes with the operating system, so you may want to point it there until you get a better program like photoshop or corel photopaint.
Mar 04, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
There is no application registered for this event is the message I get when pressing the buttons on the scanner (email/copy/scan buttons)
In the software setup, there will be a place where you program each of the Application Buttons to access a program you have installed on your computer.
Examples are: Photoshop, Email, OCR, Corel Photopaint, etc. any program that could use a feature called, "Aquire" which is simply getting a graphic from the scanner.
Be shure to install the Applications disc that came with the scanner, (not just the driver). And run the configuration, or settings tool, to set up what programs will run when you press the Quick access buttons on the scanner.
Otherwise, you can access the scanner features from a menu item called "Aquire" in Photoshop, Corel photopaint, or in Microsoft Office it's in the menu, string Insert - Image - from scanner or camera.
There are some complications with the WIA driver, and reccomends using the ScanGear CS software instead. I'm guessing WIA is (Windows Interface Access, or Windows Instant Access) whatever, it is, it is the buttons you're talking about.
I downloaded a driver from Server 1, Here, to get an Idea about your hardware. IF that link dosn't bring you to a site that says,
"Downloading Driver Canon CanoScan LiDE25"
then start here a few steps back, and find your model number in the list.
If you have the driver disc for this device, just use that,
if you have already done that,
find your scanner software on the Start Menu, and look for a configuration tool.
Hope this helps.
Dec 12, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
I keep getting a Twain error, how do i get it to work?
The Twain driver is used to scan images into the computer.
It is either corrupted or deleted.
Reinstall the Canon scanning software, it includes the Twain driver.
Oct 18, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Printing an enlarged version of a scanned photo
The best way is to use software like Corel PhotoPaint and RESAMPLE the pix to the sze you want. YOu typically will get better resolution.
You could also try selecting the "Fit To Page" setting of the printer window before you tell it to print.
Sep 14, 2009 | HP Photosmart C6280 Printer
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
I need a twain driver
I can understand that u get TWAIN driver not installed or required error on PC while scanning.
Twain drivers are imaging driver which are bundled with complete software.
Incase if you try to replace just the twain driver it may corrupt anoth files.
It is always advisable to clean the computer and reinstall the complete software.
Jul 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
384 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
