Question about IBM Infoprint 40 Laser Printer
454 fuser failed - IBM Infoprint 40 Laser Printer
2 Suggested Answers
  • 81 Answers
SOURCE: 454 FUSER ERROR
Nothing you can get around. It needs a new fuser which heats the toner to bond to the paper. You will need a service provider. If you are a business, you should look into service contracts where you pay a per copy service and everything is covered.
Posted on Jul 01, 2010
New Fuser is not being recognized by machine . . .
There are no mechanical sensors to detect that the fuser is installed, only the connector on the fuser that plugs into the main board.The fusers in this model are not the most reliable, I would try another fuser if you have it.
Dec 17, 2015 | HP lj ent 600 m602n 52ppm ntwk mono...
Fuser error printer 50.92.11
This indicates low fuser temperature. Likely the fuser has failed. Power off, reseat the fuser and then start again, if error repeats replace the fuser. Be sure to upgrade the firmware on the printer to the current revision as HP has made some adjustments to the DC controller on this printer to extend fuser life.
Nov 09, 2014 | HP LaserJet 600 M602DN Laser Printer - M
Kyocera FS1118, error code C6000,how do I resolve this?
C6000 code is a fuser that failed to warmup.
Broken fuser heater lamp wire
The fuser temperature does not rise
after the fuser heater lamp has been
turned on.
Tttt
To resolve you will need a tech to replace parts in the fuser assembly.
Aug 26, 2014 | Office Equipment & Supplies
Error 02 454 en uvw1800 sony
02-454 Failed to detect the S reel FG during F. FWD and REW
Jan 13, 2011 | Sony UVW-1800P VCR
454 FUSER ERROR
Jul 01, 2010 | IBM Office Equipment & Supplies
Fuser melting the roller and "fail to warm up" error
you could will hae a defective thermistor. Check it out
Jun 01, 2009 | Brother IntelliFax-2820 Laser Fax
Infoprint 40 with 454 Fuser error
Sure.. the 654 is an MCU communication error, so the MCU card is
probably bad (it's located near the front left side of the printer,
under the operator panel). If the MCU is good, the controller card is
the 2nd most likely suspect.
The least expensive way to fix the problem would be to purchase a used
Infoprint 21 with a bad fuser (one that is posting a 454 error), and
put your good fuser in that IP 21. Then make sure that the controller
card in your IP 21 is good by swapping it in the operational printer,
and sell the good controller card -- you might come out a few dollars
ahead in the end.
May 14, 2009 | IBM Infoprint 40 Laser Printer
92 suburban 454 v8 failed smog .
First I suggest that you have a code check done Most large parts outlets will do this for free.Control module problems will usually set a code. Just offhand, I'd check the egr valve to make sure the valve is clean and properly opening/closing. If the inspection readings were close but not perfect, sometimes "cheating" a bit by adding 2-3 oz of acetone per 10 gal. of fuel will clean it up a bit. It will not harm the system in that concetration,and will also clean the injector.
Apr 03, 2009 | 1992 Chevrolet Suburban
OKI B6300 error message: Please reboot printer (010-349)
Detect Fuser Trouble. Replace fuser if power off and on cannot recover the fail.
Aug 15, 2008 | Office Equipment & Supplies
IBM Infoprint 40 Laser Printer Logo
21 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
