Question about As Seen On TV Sewing Machines
I need a JL100 John Lewis manual
I thread the cotton through the needle when sewing thread comes off from needle and does not stitch
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
  • 15 Answers
SOURCE: I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
SOURCE: Sewing manual for a Reliable or Sailrite
The problem is that you purchased a clone of the Sailrite Ultrafeed. Most people do not know how much work Sailrite puts into each Ultrafeed Sewing Machine before it is shipped to customers. They hold 17 patents on the Zigzag Ultrafeed and know this machine inside and out. So when each machine goes through the assembly line in Indiana they are then tested by Sailrite in 2 layers of canvas then 8 layers of canvas then 4 layers of vinyl fabric if it does not sew it flawlessly they fix it, Ultrafeeds work right out of the box! So, it is highly unlikely that you will be able to get the clone machine to work. It must be totally rebuilt (a 4 hours process for an experienced technician). Sailrite will not work on any clone machines. So get your money back and buy a Sailrite Ultrafeed! If you are desperate and can not return the machine you can buy a DVD that Sailrite made for the Ultrafeed (each Ultrafeed purchased gets it free) it can be purchase here: http://www.sailrite.com/Ultrafeed-Advanced-Maintenance-DVD . It will help with timing issues, but will not show you how and what to do to rebuild the machine.
Posted on Jan 01, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
Why needle is not catching the bobbin thread
All problems like this are caused by incorrect threading of the cotton thread. Even if you have done it before, thread the cotton using the instructions in the manual.
Also make sure the bottom bobbin and its housing are correctly inserted.
Aug 15, 2015 | Singer 3321 Talent Sewing Machine
Slanting stitches
try changing the needle
also the machine could need some type of adjustment, only a sewing machine repair technican can say for sure
Mar 28, 2014 | Janome Sewing Machines
My Brother LS 2160 is threaded but not stitching
Hi there Kathryn... when you load/thread the top cotton through the machine.... and then through the eye of the needle.... do you also load the bobbin case... or is it already in there and loaded as per instructions... ? What I normally do... is load up the bottom and top threads first.. making sure to put the top thread through the needle and make the thread end go through and behind the 'foot'... when placing on fabric to try... I make sure to load the fabric... with the top thread's tail going out through the presser foot and behind your foot.. sometimes.. if its the thread (some machines don't like certain threads)... I will manually (wind the right hand wheel) so that the machine does a few stitches.. before I use my foot pedal!.. I have both a serger/overlocker... and a Brother 8500 (sewing/embroidery machine).. I have been sewing for over years now...
You will need to change your needle... when you've used it for more than 6-7 hours continuously.. OR you notice that the stitches are not as they should be... in your fabric...
Mar 22, 2014 | Brother LS 2160 Sewing Machine
Sewing machine clunking and missing stitches
the best advice is having the machine serviced, but here are some other suggestions
Jan 29, 2014 | Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
Singer featherweight 11 cotton keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 28, 2013 | Singer Featherweight II 117
No zig and cotton keeps breaking
Make sure you have a new sharp needle installed for both problems and sometimes you need a particular kind of needle for the fabric. Also some machines don't deal well with 100% cotton thread. For some reason it gets caught up in the machine somewhere and breaks. Gutterman and Metrosene make excellent although slightly more expensive threads. Coats and Clark thread is good too. They make an all cotton thread but it doesn't come in as many colors. If you have the old spools of cotton thread from Walmart, just use them for topstitching if you need the color. Other wise, use them for hand stitching or throw them away. One more thing that I can think of off hand, one of my machines does not like lining fabric. For some reason the thread breaks if I stitch really fast. If you have to use that thread, you may try sewing slowly. One more thing, when was the last time your machine was serviced? This can make a huge difference if it's been awhile and you use the machine a lot. Good luck. Hope any of this helps.
Apr 01, 2009 | Janome Sewing Machines
Sewing Machines Logo
60 people viewed this question
Top As Seen On TV Sewing Machines Experts
Harjeet Singh
R.A. Ellis
R.A. Ellis
CrisO
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
