Question about Garden
Location of spark arrestor on ryobi rlt30cesa strimmer
Product was purchased in 2011
4 Suggested Answers
  • 5 Answers
SOURCE: Starting problem with a Ryobi rlt30ces petrol strimmer
Hi
I have had the similar problem & spent a day stripping the unit down
(dismantled & re-assembled the carb, seemed OK fuel reaching & flooding the plug) I unscrewed the spark plug from the body, but left it connected to the lead and found that there was intermittent spark when pulling the cord. and tested it with a continuity meter - no signal/measurement. bought a new spark plug, meter reading showed signal/measurement, now starts every time. It may be that Ryobi has been installing rather cheap nasty plugs. So test the plug first by watching the spark when pulling cord, test with a meter, if no continuity, buy new plug....
Check also that little gauze air filter behind the roto choke is not blocked.
this solved it for me.
Please remember to give me a rating ...ta
Posted on Feb 05, 2009
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Posted on Sep 10, 2009
Testimonial: "Thanks. Got it."
rycgl
  • 1545 Answers
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Jul 10, 2010
I have Ryobi head and I cAN'T get a spark Mod# RY30040A I need to know where spark ARRESTOR is.
Hi plattsacre
Your spark arrestor is inside of the muffler...you must dissassemble the muffler to clean or repair/replace it.
Please take time to rate me
Bud
Mar 18, 2013 | Ryobi Garden
Where is the spark arrestor on the RY26000
Hi James Ferguson
Your spark arrestor is in the muffler of the trimmer.
You will dissassemble the muffler and there will be a type of screen/metal with holes,etc...that is your spark arrestor.
Clean and reassemble and your good to go
Bud
Also go to the following webpage to see a spark arrestor cleaning, not your model but it will still apply to your weed trimmer maybe different steps.
http://www.youtube.com/watch?v=kA68zpEajnU
Oct 20, 2012 | Ryobi Garden
I purchased a reconditined Ryobi grass trimmer ZRRY34440 and I trying to understand how to used the unit. There is no spark plug on it . The manual mention a spark arrestor and a spark plug part number in...
Hi imgonzalez10...
The Spark Plug part number is what you need if you are going to replace the spark plug because it is faulty,broken,ect.
When you go to the parts house to get the Spark Plug that is the number you will give them to get a correct new plug.
The Spark Arrestor is a device that goes on the exaust to stop sparks from being discharged from the engine into the enviroment.
Jun 25, 2011 | Garden
Where is the Spark Arrestor located on a Ryobi SS 30 Trimmer
It will be on the muffler. What you are looking for is a screen mesh. If you cannot see through this mesh then you need to clean it before putting it back into the muffler. You can clean it with a propane torch and burn off the carbon deposits.
Mar 30, 2011 | Ryobi Garden
Jul 09, 2010 | Ryobi Garden
I have a Ryobi brushcutter that is 4 years old.When I was using it the other day it just would not run at full throttle. I checked spark plug,air filter and fuel filter. No adjustments on carb. I have no...
Smokey 2 cycle oil will cause the exhaust ports to carbon up and plug the spark arrestor.
Remove the muffler, use a pick to clean out the exhaust port on the engine, and the muffler inside opening, then clean the spark arrestor screen, to assure yourself you are correcting the problem start the machine up with the muffler off, it should run like a charm, if it goes back to running badly when you reattach the muffler it may be clogged on the inside.
Jun 14, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi model RCT2800B grass strimmer will not start
close your carb adjustment screw a bunch of turns... yours may even be missing.
Apr 19, 2009 | Ryobi Garden
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
