Question about HP PSC 2410 All-In-One InkJet Printer
Makes noise on scaner
Makes noise and led flashs
    Master:
  • 638 Answers
It needs servicing to work properly.as something is blocking the gears to move freely so the noise is coming and led is flashing.
Posted on Nov 14, 2008
My 99 ford windstar check engine light is flashing and there is a loud tapping noise coming from the motor what do i do
flashing light could be codes from obd ,did you get any codes with scaner?
tapping noise could be a few things from oil pump , little oil in moter,bent push rod,dry lifter ,need more info of codes/ let me know ,and i'll try to help more.
Oct 01, 2012 | 1999 Ford Windstar
Canon mp 140 printer/scaner after cartige refill cant print, led still flashing, did reset no luck what can i do next, the printer seems not responsible!!!
Hello! here is your solution.
Press stop/start button for 5 seconds without release. Your printer will start function.... thanks
Aug 31, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Lines on printout of scanned image
The problem is with Scaner.
There will be any dust particle is on the purticular sport of scaner, try to clean the scaner.
If any one or more Photo Diode damage (Used in Scaner which glow) then also the problem will be
there.
Change the scanner if damege (Open the top lead and press copy butten then see any LED is off / not glow)
Jun 02, 2011 | HP Photosmart C5180 All-In-One InkJet...
Light horizontal lines on printout of scan
The Scaner will be faulty.
You try to clean the scaner(The glowing part)
Find out any one or more LED / Light is fault or not glow.
Change the scanner if faulty
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Picture tube not working
Please provide more info.
1. Does the TV stay on, if so,
2. Is the LED flashing, how many times stop same number of times again
3. If TV goes to stanby, count the flashing LED.
4. If LED comes on goes off , at firsdt switch on. does it make a thumping noise.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Packard Bell
Check out the following link:
http://support.packardbell.com/uk/item/index.php?i=topic_02437&pi=platform_storeandsave3500&dhepn=C050890000
It includes the following:
Beeping noise and flashing LED
dot.gif dot.gif Situation dot.gifWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously. dot.gif Details dot.gifThese symptoms indicate that the AC adapter is not providing enough power. dot.gif Solution dot.gifThe AC adapter will need to be replaced. I hope this helps, Bob
Mar 24, 2008 | Computers & Internet
TV wont turn on?!
What type of tv is this ? If it is a GE or RCA you might have a bad flyback transformer.
Feb 22, 2008 | Televison & Video
SCAN
KIMA7 and GUEST:
You have to service the scaner craddle if U want to, or replace it with a new part.
The noise is because the scaner cannot align. Under the front panel - under the glass is a white strip that should be read by the scaner in order to calibrate (find the right limit).
If there is some dust on the craddle mirrors or if the CCD sensor is fault, then the craddle wants to go beyond the right limit of the chasis - then the noise apears.
The mirrors and the lens should be cleaned, then if this noise is still there, you should replace the craddle.
In Romania there is no service part available for this printer, there is only the Unit Exchange solution. Very expensive.
Lillouie - If U have reinstalled the AIO with a new driver, you should have a list of scaners that you can select. 2 mabye.
Try from a Word doc to insert picture from scaner/camera and U'll see that there are more than one scaner in that scrolling list.
If this isn't so. Uninstall the hole printing solution from HP, then install it from clean..
Best regards, Sebi
Dec 28, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
