Question about Toro Garden
I HAVE A TORO PROSTREAM LAWN SPRINKLER, MODEL #71031. I NEED TO KNOW HOW I CAN ADJUST THE RADIUS AND THE PATTERN
I'M MOVING THIS SPRINKLER TO ANOTHER SPOT IN THE YARD. I LIKE TO CHANGE THE RADIUS AND PATTERN OF THE SPRINKLER SO THAT IT SERVE WATER TO THE YARD BETTER. I HAVE THE ADJUCTMENT KEY BUT NO INSTRUCTIONS
3 Suggested Answers
SOURCE: I need an owners manual
http://media.toro.com/documents/solution-center/diy/LMII_User_Guide_53805_53806.pdf
Posted on Jul 10, 2011
mbond177
  • 3 Answers
SOURCE: my hunter SRC lawn sprinkler controller sprinkles t
First thing to check is the power supply. Are the batteries fresh? Most likely you need to reprogram. There is likely a previous program that is causing the errant watering. Here is a good video on how to program.
Posted on Oct 25, 2011
Tip
Haste to stop waste!
Too often we let our irrigation systems go on without really making sure that the amount of water, the pressure, the radius and other settings are what our lawn or landscape needs.
This causes not only a great waste of water and money but it may also ruin our flowers and plants.
Therefore here are a few tips to transform a wasteful sprinkler irrigation into the effective system it should be, and to keep a healthy landscape, lawn or garden.
1. When to water.
Watering your lawn and landscape should be differentiated according to seasons.
During warm months (May to October) irrigation should be activated between midnight and sunrise, so to minimize the water that evaporates.
While during winter, plants and lawns should be watered during the warmer part of the day to prevent water from freezing on the landscape.
2. Don't drown your plants.
Keep an eye on your lawn while the sprinklers are on and monitor when the water starts dripping off the sides. This way you will know how long your sprinklers should be left active for, so that the plants may absorb the water without being overwhelmed.
3. Avoid daily, light watering.
4. When watering plants with deep roots, water well and deep, until about half inch deeper than the deepest roots, in order to encourage downward growth.
5. When watering on a slope do it gradually. Run your sprinklers every 3 hours circa and aerate to increase infiltration.
6. Check your sprinkler's efficiency once a month.
Check for damaged, leaking, clogged or stuck sprinkler heads and for constantly soaked patches of grass or soil to detect leakage.
Make sure that the water is sprayed all over the area and that new additions or plants that grew higher and larger don't block the spray pattern.
7. In seasons in which the temperature reaches 30/32 degrees Celsius remember to run your sprinklers 5 to 10 minutes in the afternoon to cool the area. It reduces the symptoms of summer patch disease.
8. Create water zones by putting together the plants that have similar water needs, and water them accordingly
9. Be careful when mowing. If your sprinkle heads don't retract underground after irrigation, apply small flags on them so that while mowing you see them better and avoid damaging them.
on Sep 09, 2013 | Garden
Sprinkler will not rotate
May be full of dirt. Or low water pressure
Apr 21, 2014 | Toro 53823 ProStream XL ProStream XL 5...
How to adjust the spray pattern on the 570 series pop up
Change the nozzle. If it is an adjustable nozzle change it to a fixed spray with the desired radius. 1/4, 1/3, 1/2, 2/3, 3/4 patterns are available.
Mar 25, 2014 | Toro 570Z Pro Series Black Pop-Up...
Is there a video on programming a toro lawn master II timer
I have found these timers to be the most difficult for a homeowner to master. I suggest going to Toro's web site and downloading the operating instructions.
Sep 30, 2013 | Toro 53805 Lawn Master II 4-Zone Landscape...
Toro lawn Master ll timer (53805) keeps repeating station cycles even though I only use Program A with weekly , time starts, zone times, " 0's" on Program B & C and"...
The "start times" are often mistaken for zone start times with this model. These times are actually if you want your sprinkler to run/start more than once a day. If you only want your sprinkler to run once a day, then you should set start times number 2 and 3 to "OFF". The "OFF" setting is between 11:45pm and 12:00am as you cycle through time settings.
This is not in the manual. You're welcome!
Jul 18, 2011 | Toro Electric Trimmer
Hunter sprinkler head adjusting...
I googled Hunter sprinkler heads and where to purchase them. In my area (the East bay, Tri-Valley) in Nothern California.
I went to Ewing Irrigation in Dublin, CA and found the Hunter sprinkler heads there. The man working the counter got two for me and he demonstrated how to change the head by unscrewing it from the base at or just below ground level by removing the old one and screwing in the new head. He also showed me how to adjust them with the spray pattern. You will need the little tool that comes with the sprayer head.
Making sure the center arrow is completely to the left and rotate the head to the right then back to left. They are set to a 180% spray pattern from the manufacturer. If you want a bigger pattern you turn the adjuster toward the ( + ) side and if you want less pattern you turn the adjuster to the ( - ) side. He showed me how to install the red sprayer inserts by simply pushing them in the cavity making sure the little u shaped indentation is pointing up to allow for the set screw to go through to adjust the spary.The spray varies in distance and amount of water being emitted from the head depending upon the insert used.
I was able to replace the Hunter head, adjust the spray and changed out the insert a few times until I found the one I liked. I used needle nose pliers to remove the initial spray insert that the man @ Ewing installed until I found the one that worked best.
I found using needle nose pliers makes it very easy to grasp the little inserts for replacing.
-Terry
Apr 04, 2008 | Ace Hardware Hunter& Low Profile III...
Garden Logo
256 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
