Fitting door seal to a zanussi ZWF12070W - Washing Machines
  • 1462 Answers
SOURCE: the door seal needs changing
not too bad a job. remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery. to fit new seal lubricate the slot which fits over the tub with washing-up fluid - essential! starting at the top, press the seal so the flange of the tub enters the slot on the seal. work your way round the using thumbs to force the slot on the tub flange - easy when you have done it once but hard the first time. when slot is on the flange all way round, fit the spring which holds it on.the spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands. fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring. test for leaks before using in earnest. use rinse to test as the water level is higher
Posted on Mar 27, 2007
SOURCE: zanussi jetsystem 1400 door seal
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
Posted on Oct 09, 2008
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
  • 1294 Answers
SOURCE: fitting of door seal on zanussi electrolux washing
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Posted on Mar 12, 2009
SOURCE: change the door seal
Not sure if its the same type but I just changed the door seal on a Zanussi ZWF1221W washing machine. It was a lot easier than I was expecting but this way does take a bit longer. Before starting disconnect the mains and water supply and drain hose. If possible move the washing machine out so you can get around it.
First I used a small flat head screwdriver to open the teeth on the outer door seal clamp that holds the seal in place. The old seal then peels off the front of the machine. You can continue the process without taking the front of the washing machine off but it is much, much easier to take it off if you can.
To remove the front panel unscrew the two bolts at the top corners of the back panel and slide the top cover off towards the back and lift it off. Then remove the two bolts that attach the plastic control panel to the front of the machine (either end of the top, front edge), remove the detergent dispenser drawer (you need to push down on a lever at the back) and take the screw out of the front of the machine (revealed when you take out the detergent drawer). Then carefully remove the control panel and the two bolts that hold the front panel on.
Then (very carefully as washing machines are heavy) lie the machine on its back and remove the three screws from the bottom that hold the front panel on. Then unplug the cables on the inside of the front panel that operate the door lock (its a plug with a plastic cover - just pull it out but don't pull the wires!).
Now you can lift the front panel off which is the key to making this job really easy as you're not trying to fit the new seal through the door which makes it really tight.
With the machine still on its back find the spring that stretches all around the seal to hold it on the drum and remove using a flat head screwdriver to pull it out of its groove. You can now pull the old seal off.
It's a good idea to put some fabric softener or liquid detergent around the edge of the new seal to make it easier to fit on to the drum at this point.
Find the arrow that points to the top and starting here attach the groove of the new seal to the plastic drum all the way around. You have to press quite hard but you can tell when its properly attached to the drum. Once this is done replace the spring so it sits in a groove on the seal holding it to the drum.
Now replace the front of the panel of the machine by doing the reverse of all the earlier steps (remember to reattach the door lock) and stand it back up on its feet (careful it's heavy). You can now replace the top panel of the machine (slide it on and replace the two screws).
With the washing machine back upright you can attach the front of the seal to the door opening of the front panel (the arrow should be pointing upwards). Then you can reattach the clamp that holds the seal around the door opening and then secure the teeth on the clamp so it's tight (I don't know if it matters where around the seal the clamp goes but mine's at about 7 o'clock).
Now all you need to do is reattach the drain hose, water supply and mains and test it doesn't leak. A rinse cycle uses the most water apparently so it might be worth using that.
Hope this was useful.
Posted on Jul 24, 2009
Fit door seal on a zanussi washer
This is not easy and there is a real knack to it. You will find it easier to have a second person helping. One holds the spring in position at the top and the other at the bottom and roll the spring over your hands into the slot
diug
Dec 04, 2014 | Zanussi Washing Machines
Fitting new door seal
Hello,you mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install
Thanks
May 28, 2010 | Zanussi FS1155W Front Load Washer
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
May 21, 2009 | Refrigerators
Fitting of door seal on zanussi electrolux washing machine model aquacycle 1200 xc6 how do you get the the the door seal fitted finding it impossible almost
To fit new seal
Mar 12, 2009 | Zanussi FLA1201W Front Load Washer
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi Freezer ZVC67 - replace the seal
yes u can fit it yourself the door seal shoould just push in which u might hear a small click when it is in properly not a major job m8
Aug 15, 2007 | Zanussi ZEBF250W Bottom Freezer...
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
