Question about Hotpoint HSS25GFP Side by Side Refrigerator
GE Hopoint Model #HSM25GFTA SA
Refrigerator is defrosting more than once a day.
    New Friend:
My refrigeration no out water ....
Posted on Nov 15, 2012
3 Suggested Answers
  • 2468 Answers
SOURCE: I have a GE model TFX30PPDACC. It had frost in
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Posted on Jun 12, 2011
heatman101
  • 43501 Answers
SOURCE: HSM25GFTA sa defrosts and melts
The defrost termination thermostat is not working, causing the defrost to stay on too long...
Click here for the part you need to fix it...
Change this out and your back working correctly again..
heatman101
Posted on Sep 13, 2011
Hotpoint hsm25gfta sa
Check for a device called a damper in the refrigerator compartment. It controls how much cold air from the freezer is sent to the refrigerator. In my recent experience with a bad damper in a GE side by side, the damper door broke and the refrigerator got too cold. The damper door could be broken or the motor failed and left the door closed. If this happens, the refrigerator compartment will not get enough cold air from the freezer and run warmer than normal. Check the appliance parts web sites for a breakdown of you model. You may find it's a major disassembly to get to the control. What I did was remove the bad part and control the airflow from the freezer with a partial blockage until I got a new part and the time to repair it.
Apr 17, 2014 | Refrigerators
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
I own a GE Refrigerator model#GBS18HBRAWW Bottom
if you mean the freezer froze up and you replaced the defrost thermostat in the freezer,then you need to check the continuity of the defrost heater assembly located on or under the evaporator coil for continuity(completed circuit) with at least one of the leads to it disconnected,if this shows good,then you need a new defrost timer,be it an adaptive or timer type,last but not least it could be a bad connection and this circuit could be losing power and needs to be checked,but this is very rare
Jun 06, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
Water is leakig from behind the control panel
You did the right thing by trying to clear the drain in the back of the freezer, but it must not have cleared. If the ice maker is not leaking then the only other source of water can be defrosting ice build up on the evaporator coils when it goes through its cycle. You know your drain is clear when water can flow down it. Defrosting your refrigerator completly usually solves this. If it does not, then check to make sure the freezer compartment fan is working, next it may be either your thermostat or timer control. Those are pretty much the only possibilties.
Aug 25, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator has been used for 12 years, but it's
your on the right track. underneath the evaporator there is a drain hole that leads to drain pan. remove rear wall in freezer section. check for ice build up in hole. ive even pulled out a jun bug out of one before
Jun 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
GE Model GSS22JEMB WW - Defrost heater Bad
yes, remove the freezer panel and defrost with blow dryer. will work for about 5 to 7 days.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
93 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
