Question about Philips LX3600D System
Philips lx3600d doesn't turn on
Hello,first i come from holland so i hope you don't blame me if i don't write english so well.
I have a problem with mine philips home cinema lx 3600d.
If i want to turn it on the power light just blinks ( so it goes on and of repeately)
Whem i manually push the power button it has the same problem.
I hope that anywone can help me.
5 Suggested Answers
vashkar
  • 3 Answers
SOURCE: Wont work
check front PCB
Posted on Oct 30, 2007
rizla
  • 1463 Answers
SOURCE: Philips DVD LX3600D
just type in to google make-model of dvd player and region codes
and search for the one you want .
riz.
Posted on Feb 08, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: about price
Without home theater, it would be zero, since the entire unit is referred to as a home theater system.
The Philips website will list the MSRP for the HTS.
Philips tech support will give you an out-of-warranty price for replacing the device.
Ultimately, the price of the device is what you end up paying for it.
I'm not trying to be sarcastic - there is just no other way to answer the question.
Posted on Feb 19, 2008
  • 1779 Answers
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Posted on Apr 11, 2008
bob_computer
  • 3153 Answers
SOURCE: Connecting a computer to a LX3600D Home system
Lots of people are doing this and part depends on what your home theatre has to offer in the way of connections.
For sound most use the LINE OUT on a computer or laptop and connect that to a suitable input on the receiver using a 3.5mm to stereo phono lead.
If you are lucky enough to have an OPTICAL sound out on your computer and one on the home system that would be a better option.
For the video side again it depends on what your computer has to offer
If it has DVI and your TV or home system has DMI then that is the very best option. remember to lower the resolution on the computer first and to check and of your graphics card options for dual display. A DVI to HDMI lead is needed for that
Nvidia graphics cards seem to work best in this area.
If you have a VGA connector on your TV that is another great option and you would only need a VGA lead.
Some cards and laptops have S-VIDEO out. Lots of TV's and home systems have these and the display is quite reasonable. If using S-video connections use a GOOD quality cable.
Some people can only obtain a black and white picture so check your graphics card did not come with any special adaptor.
Another method is composite video Even that is not always 100%
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it.
Using a VGA to component lead is also an option but results vary wildly from no picture to quite good. A lot depends on the quality of the lead once again.
I use the optical sound and DMI lead to power a 50" Sony with great sound and picture.
Posted on Sep 19, 2009
Philips lx3600d dvd surround home theatre system dvd player fault
when the dvd is inserted it shows up no disc so it is not loading
Jan 09, 2010 | Philips LX3600D System
My Philips LX3600D returns always to stand-by mode
The speaker cables for the LX3600D are: (+) is blank, whereas (-) has slightly shaded bands along it. Once you see these bands its easy to open up the connector and check they are the correct way around.
Mar 15, 2009 | Philips LX3600D System
Philips LX3600D Progressive Scan problems
conect ur video cable to cymk output it apper picture and then in system seting reset the dvd player
Mar 06, 2009 | Philips LX3600D System
Mar 15, 2008 | Philips LX3600D System
Philips DVD LX3600D
riz.
Feb 08, 2008 | Philips LX3600D System
Philips LX3600D System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
