Question about Canon PIXMA MP495 InkJet Printer
How do I clean out my waste ink absorber on canon mp495 printer
SOURCE: Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Posted on Nov 30, 2007
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
I tried a few times... I have done this alot to many different canon printers. This is what worked for me.
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Good luck. I was very happy when this worked for me.
B's
Posted on May 05, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 1550 Answers
SOURCE: Reset Waste INk Canon MX318
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 16, 2008
Where is Canon printer service center in louisville KY?
Hello, Tanya -
I tried using the Canon Find A Service Location web page,
https://www.usa.canon.com/internet/portal/us/home/support/service-repair/servicelocation?cm_sp=CSO-_-support/service-repair-_-Service-locations
but, it seems the search logic does not accept MP495 as a valid Canon printer model number. Do you mean the PIXMA MP495? If so . . . this is what came up when I entered PIXMA MP495 and a Louisville, Kentucky zip code:
[Quote]
Service is No Longer available for This Product
Please be advised that repair service is no longer available for this product. However, in appreciation of your continued loyalty, we would like to fully understand your immediate needs and offer an alternative solution. If possible, Please call us toll-free at 1-866-481-2567 to discuss available options.
Thank you and we look forward to supporting your future Canon products.
[End quote]
While trying to find more information on the Canon MP495 printer, I came across information about the 5800 error code and the ink absorber being full, here:
https://www.justanswer.com/printers/alh67-error-5800-canon-printer-mp495-ink.html
26 Aug 2017
Question:
HI an error 5800 came up on my canon printer mp495 that my ink absorber is full. How do i clean it? . . . [snip] I have the printer about 2yrs and i haven't updated software
Answer:
Unfortunately, there is no quick or easy fix here. This message indicates a hardware problem, specifically that that the internal "ink absorber system" is full. The ink absorber is a series of pads/tanks, which catch drips from the printhead when parked, and is also used for maintenance tasks like cleaning and purging.
Eventually this absorber fills up, and the printer shuts down operations, as continuing to operate it can result in ink overflowing the system, damaging your desk, flooring, etc
While it is sometimes possible to temporarily reset the counter, this is dangerous as the system will likely overflow. Cleaning/emptying/replacing the system is a difficult and messy process as well, best left to a qualified service technician. This service is generally not practical though - it's going to run you $150-250 for repairs, which just isn't worth it for an older printer. This is a 7 year old model, that was built for a service life of no more than 3 years. If you have reached the point that the absorber has filled, then other wear items like the printhead, feed rollers, etc are also going to be at the end of their lives and need service/replacement soon.
Given the costs and complexity of fixing this issue, you'd be better off replacing the printer. You can get a brand new and better machine, with current technology and a fresh warranty, for about $80, which makes more sense than investing in the older machine.
I can recommend replacement options for you if you'd like, or if you'd prefer to try having it serviced or working on it yourself, I can advise further on those options. Replacement would be your best bet though, economically speaking.
From other information I found, it appears the Canon PIXMA MP495 came out in mid-2010. Do you recall when you purchased your printer? As the long explanation I posted above states, the estimated service life of the PIXMA MP495 was no more than 3 years.
So, your only option seems to be to purchase a new printer.
Sorry.
Jan 30, 2018 | Canon Office Equipment & Supplies
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
May 22, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
How do I clean the waste ink absorber on a cannon ip90
We are not advice to clean WASTE INK ABSORBER.
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Canon PIXMA MP495 InkJet Printer Logo
1,192 people viewed this question
old marine
old marine
