Question about Vizio VX20L 20 in. LCD TV
Dead, no power. stand by voltage is there. all fuses are ok. Seems like a dead small signal PCB. any feed back appreciated. JR Eelectronics.
  • Vizio Master
  • 5,568 Answers
Unfortunately, your problem is another one of thousands; I spend half of my time here pasting in the following explanation and if it touches on things you already know, just blame my laziness in customizing messages:
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not likely be able to do the repair yourself.
Modern power supplies are designed to shut down if the current drawn exceeds the design level, which indicates that something the supply services or the supply itself has died.
If you are adventurous, you might pull the plug on the set, allow the set to sit overnight, gain access to the innards, and with good light, inspect any boards inside.
If you see one that has few ICs but many more larger discrete parts, this will be the power supply.
Again, before touching anything inside, especially on that board, allow at least several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
You are looking for components called electrolytic capacitors that are almost always cylindrical and mostly installed upright at 90 degrees to the board with leads passing through to the solder side.
This same type of component in smaller dimensions is still used in a horizontal package with leads bent down and passing though holes to the solder side.
The latter are becoming more rare since they don't lend themselves well to robot assembly.
Many failed caps (not all) will show signs of pregnancy when they fail, bulging unnaturally at the top when compared with others. Now and then, there may be traces of a crystalline deposit around the end where the seal failed from internal pressure.
These will have values listed on them in uFd & VDC and sometimes, a plus/minus number lying about the precision.
Some also have a date code (rarer) that will look like four digits:
2403 = 24th week of 2003
Most electronics suppliers have a stock of the various values but if they have a date code at all, try to get only those made before 2002 or after 2006.
The larger caps will probably be OK since the failure is likely related to functions other than brute-force filtering. A pretty good 'rule of thumb' is to replace any caps you see bulging of any value but especially those that are 100 uFd or less.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace it or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
If you choose to replace failed caps yourself, you will need a quality soldering iron with a small, preferably iron-plated tip, rosin core solder and a sponge which when wetted is used to frequently wipe oxidized solder from the tip this should be kept bright and clean and fresh tinning will keep it that way.
You should also buy some solder 'wick' with the iron; this is used to place on the solder you wish to remove and then heated with the iron. Properly used, the wick will absorb nearly all of the solder from the lands from which you wish to remove a component.
Posted on Oct 23, 2008
How to repair left turn signal and brake light, changed bulb, No voltage in fuse box, fuse is ok
No voltage. Replace the turn signal switch. All the exterior lights run threw it. Except the rear high brake light.
Apr 08, 2015 | 2013 Jeep Wrangler
Hi, I have Plasma TV Power Supply Board. The model of board is: LJ44-00144A PS-506-PH. The stand-by voltage 5Vstb works just fine. When I turn on the TV the Stand-by let in front of it comes blue like...
I have the same problem. As I see, here is dead sub PCB with microcontroller on board. Small PCB with 26 pins, mounted verticaly on main, big power supply board. It is not available as a spare part. You must buy complete power supply board LJ44-001444A, as I have done.
Aug 09, 2011 | Philips POWER SUPPLY (41644158) Power...
Toshiba model#57H94 dead set push power switch nothing want start up dead main ac fuse check good.Sam's Tv Service any help will be appreciate. Thanks
Check hori output and small blue high voltage capacitor 2k that feeds hori output transistor.
If these componets are OK then replace Both of the STK ICs they are big black ICs and will have PN# on them.example STK392-110.
Mats Electronics has ICs 1-800-628-1118
Encompass Parts Distribution has Free Service Manual for this Model# 57H94 you can print it out online.Go to their website.
Jun 05, 2011 | Toshiba 57H94 57" Rear Projection HDTV
Model # TH-42PX80U tv was on when a storm hit 'lightning' , on lite only blinks... is it a fuse ? or mother board?
You are better off replacing the power supply board. Usually the mother board will output a power ok signal to turn on the TV only when the power supply is working correctly (all voltages are within specs), similar to a computer, having said so, if you have the schematics you can verify those voltages being output from the power supply upon depressing the power button. The +5v stand by voltage is most likely ok, since the mother board is at least providing you with the blinking light. It is the +12V and +24V which are not being output, along with any other auxiliary voltages. I would suggest either having a replacement board (power PCB) installed or otherwise feeding the needed voltages by substituting those missing ones with a variable DC power supply, just to verify it. Follow above only if familiar with electronics and electricity. safety first!.
http://www.HDalacarte.com guy audio/video/computer technician for over 30 years
May 26, 2011 | Panasonic TH-42PX80U Plasma TV
Our TV just went dead. We unplug it and plug it
First Check small Blue high voltage capacitor 2kV Feed to the hori output Transistor Near your FBT flyback Transfomer If they are OK then replace Both of your STK ICs they are big black ICs will have Part number on them example STK392-110 Call Mats Electronics for Parts 1-800-628-1118
Dec 15, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Our microwave went dead. It's only three years old. My husband put some chicken wings in, closed the door, and everything went black. We plugged in a nightlight in the power source and it worked. Any ideas...
a few possible causes,
1, the high voltage fuse,
2, the high voltage capacitor
3, the slow blow fuse ( normally found on a small pcb inside unit)
other than that, check the door switches and maybe the x former.
good luck.
Jul 04, 2009 | Whirlpool GH4155XP Microwave Oven
RCA d52W19Byx1
Check to standby voltages, the three of the five and a 7.5 voltage going to the SSB main PCB if these voltages are there most likely have no horizontal drive.  You'll need to replaced the SSB part # 264120. I recommend that you have an authorized RCA servicer replaced the board, convergence data needs to be uploaded to a computer via a chipper checker.  Because a full convergence is quite difficult.
                                      Packman
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Fuses check ok, dead no power
it could be high voltage cap located by flyback,if you have back off of tv and turn tv on,you will see green led's turn on,(on the board)if they turn off there is a small blue high voltage cap hidden under glue(i believe it's a 102 cap)that would be the one change,99% of time that is what will fix problem
Sep 22, 2007 | Televison & Video
Vizio VX20L 20 in. LCD TV Logo
203 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
