Ms-7592 wiring diagram
Bios chip pads need replaced on a a7592 bios chip question were from mother board do i wire the pads ? i am trying pin 1 to jspi1 pin 5 so pin2 to under board wirewarp wire to test padat centerjspi1 thorough vc hole wp# pin3 to rest off jspi1 need verification
  • 231 Answers
SOURCE: Requared bios updated versin for foxconn 865gv chipset mother board
Hi, I run a foxconn mobo myself and yes its a great board. But dont go to the foxconn site looking for downloads. instead go to the VIA site they make the chips and you will get more sense there. If all else fails Foxconn do have a "Contact us " link on their home page. This will give you the company email address and you could request directions to the update site there, the only trouble is it could take weeks to get a response. Regards mistyman
Posted on Aug 21, 2007
  • 21 Answers
SOURCE: n1996 mother board
The only way to to fix this if your headers on your wires aren't labeled is to trace them back from the switch it self. Usually they are white and red. The orientation on the motherboard pins doesn't matter since it's only a switch. Make sure you are putting the plug onto the power switch jumpers, and not the power led, reset, etc..
Posted on Jan 07, 2008
  • 1019 Answers
SOURCE: jumper setting on motherboard
You could,nt find it Because It,s listed under Archive Boards.
I think this Is what your looking For, You can also download Drivers Et,c.
Please don,t forget to Rate This Post, Once you,ve Fixed Your Problem.
Many Thanks Mike @ Compurepair.
Posted @ 21.48PM ( G.M.T )
Posted on Mar 05, 2008
  • 287 Answers
SOURCE: MS 6577 ver 4.1 wiring
This should help - it may not be exact model but it is from the same series.
LINK page 2-13
BTW this is a HP PC board made by MSI and there were a few versions.
Posted on Jul 17, 2008
  • 293 Answers
SOURCE: pin configuration for front panel on n1996 motherboard
n1996 is NOT the model number. ALL MSI boards are labeled n1996 - it's their C-Tick number. You need to find the actual model number which should be listed on a sticker near the main CPU socket. Search for that on msi's website.
Posted on Sep 14, 2008
I have a desktop with an amer megatrend bios.I want to get a new bios that works with win 8.1 and needs to have support for PAE,NX.and SSE2
It's best to simply replace the entire Mother Board than try to replace the BIOS. Replacing a Mother Board vs replacing a BIOS is way easier.
Your current BIOS MIGHT work if you can find a flash file for it, but you have to be careful. If the BIOS your flashing isn't in production it's usually only PATCH flash file, to fix a problem with a BIOS, not upgrade it. And if you use the wrong flash file, it will TRASH your BIOS!
The BIOS, which is a chip, is usually micro-soldered to the Mother Board with high precision, by a robotic arm, and not easily removed or duplicated. The exception is if you happen to have a BIOS chip, that can be replaced, in a socket, but this is unusual instead of common.
The best source for BIOS info such as you are looking for is the American Megatrends Website itself at: AMI American Megatrends Inc Aptio (compatible with Windows 8) however their website is for the Mother Board manufacturer so you can't buy the BIOS as a consumer, but through a reseller, AMI Office, Authorized Representatives, etc (AMI American Megatrends Inc How to Buy).
You can however, buy a replacement Mother Board with a BIOS already installed on it (that's the way you usually buy them - with the BIOS pre-installed on the Mother Board) that's PAE, NX, and SSE2 and whatever else you want compatible. A great website to find computer parts and kits, new, refurbished, out of box, etc is the Tiger Direct Website at: TigerDirect com Electronics Tablets Phones Office Supplies Video Games. Just search for BIOS to find your specs, then check the bottom for possible best Mother Board kits to replace the one you have now. Hope this helps. :-)
Mar 03, 2014 | Computers & Internet
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
KK266 mother board (IWill) need a wiring diagram, usb is not being identified
Antec doesn't make mother boards, they make enclosures. The standard USB connection on the board is a 2x5 pin connector, with 1 pin missing. The end that has the missing pin, is the end that the cable shield is attached to.
Mar 24, 2010 | Antec Computers & Internet
My toshiba tecra8000 laptop displays toshiba logo for 1 second and then it displays password.Bios batteries have been removed.code no of flash eprom on mother board is unknown tome.If I get the code no of...
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 09, 2010 | Toshiba Tecra 8000 Notebook
Connection of inbuolt speakers on motherboard..
Dear User,
Pl Take Your Motherboard Make and model no with its diagram.
(1) Diagram contains inbuilt speaker pin where to connect wire.
(2) Anoter way please see on your motherboard small pin when wire hang. Read Carefully around pin in small latters for speakers pin.
Feb 26, 2010 | MSI K9MM-V Motherboard
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
Can't Remember where wires go.
probably these wire nowhere connected if you have no wireless lan adapter. Usually these two wires join to built-in antenna in screen.
Mar 04, 2009 | MSI Micro-Star ATHLON/DURON UP TO 3200+...
Lost in the wiring :(
Hi bossman9628A, normally its the wire colors that messes everyone up when trying to connect the front case wires to the motherboard. The MSI RX480 Neo2-F, AKA MS-7151 MB is no different but does use a second set of pins just to help you get more confused.
Gather up all your case wires. You'll notice there is one color that is common. Chances are that color is white & is being used for the ground wire. Other colors like blue, green, red, light blue, light green & light red ECT are used for positive. The speaker uses black for ground/negative.
So looking at JFP1 at pin 1 is positive +. Pin 3, which is to the right of pin 1 is negative -.
The manual does show you which pin is negative & which is positive. Pin 1 = (HD_LED_P). The _P stands for positive.
Pin 3 = (HD_LED_N). The _N stands for negative. Do not connect the Power led at JFP2. Keep the power led connected at JFP1.
Do connect the case speaker at JFP2. Most cases do use 2-pin connectors but others use 3 & 4 pin connectors. If your case is such you can remove a wire from a connector by using a decent needle. There is a small black tab that you can pull towards your self while pulling the wire out. You can than slide the wire back into the connector where you need it. You'll know the wire is inserted correctly because you'll hear or feel it snap into the connector. If by sme chance you get a led backwards, don't freak out. The leds use 5v DC. Just shut down the system & turn that led 180deg & reconnect it.
Good luck bossman9628A!
More questions?
Mike
please vote....
Jan 02, 2009 | Matsonic MS9087C Motherboard
No display
check that your display card is seeted properly and your ram,if you have two ram chips remove the chip in socket no.1 and replace it with the other chip.
Nov 06, 2007 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Motherboard problem
if you have tried resetting the bios by putting the jumper across pins 2-3, then back to pins 1-2 and it still wont boot into the bios and you know the memory is ok, then the bios chip on the motherboard is damaged and may not be easy to replace as the board is quite old.
Aug 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Computers & Internet Logo
David Payne
David Payne
