Question about Casio FX-115ES Scientific Calculator
How to get the eigen valu of a matrix an fx-991 ES calculator
  • 7993 Answers
SOURCE: my calculator fx-991 Es is showing either syntax
How about recreating the error and reporting faithfully the error message? You get a syntax error if you try to invert a matrix by using the wrong key sequence such a
[SHIFT][MATRIX][3:MatA][X to ] -1), meaning that you use the universal power key on the same row as X squared and log and between them.
To calculate the inverse of a matrix, have the name of the matrix on the command line, (see above) then press [X to -1] key one row up from [log].
Concerning your implied affirmation that if the matrix is square you should not be getting any error: You will get an error ( a Math error) if determinant of the matrix is equal to zero.
Posted on Mar 13, 2010
christyrse
  • 45 Answers
SOURCE: steps to draw graphs using Fx 991 ES Plus
There are many different functions...
You can download the entire manual after answering a few questions at www.safemanuals.com
after using the dropdown menu for this make and model.
Good Luck!
Posted on Oct 18, 2010
  • 102366 Answers
SOURCE: how to get the inverse of a matrix an fx-991 ES
The same way you would get the inverse of a number. Assuming you already have the matrix entered into memory, press SHIFT 4 to bring up the matrix menu, select the matrix whose inverse you want, then press the x^-1 key (just to the right and slightly below the big round cursor pad.
Posted on Nov 02, 2010
  • 7993 Answers
SOURCE: How do i calculate antilog
For common logs (logs in base 10) use the 10^x function : Press [SHIFT] [Log] to access it.
For natural logs, use the exponential function. Press [SHIFT][ln] to access it.
Posted on Dec 03, 2010
  • 102366 Answers
SOURCE: how to calculate inverse
Press SHIFT [MATRIX], specify the matrix to be inverted, then x^-1.
Example #103 in the appendix shows the exact procedure for inverting the matrix entered in example #096. If you need the manual and the appendix, you can download them from
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
Posted on May 09, 2011
Calculators fx algebra
The FX-991ES Plus barely handles simple operations on matrices of dimensions up to 3X3. It cannot find eigenvalues or eigenvectors.
Oct 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
Which model of casio csn do integration in limits
The Casios FX-115 ES , FX-115 ES PLus, FX-991 ES, FX-991 ES Plus C can perfom numerical differentiation at a point, and numerical integration between two given limits.
Aug 12, 2013 | Casio FX991ES Scientific Calculator
How to calculate inverse of the matrix with 991 ES calculator ?
May 09, 2011 | Casio FX-115ES Scientific Calculator
How to interpolate in CASIO fx 991 ES
its simple
press mode
3;stat
2;A+Bx
l x l y l
l 2 l 4.6 l
l 4 l 5.9 l
press; AC
press;5.9
press; shift
press;1
press;7 (reg)
press;5 (comma)
press;=
u will get ans
Feb 08, 2011 | Casio FX-115ES Scientific Calculator
In casio fx-991ES, i am able not to get the matrix multiplication as well as inverse when i do so get math error.
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x-1]. The key [x-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Dec 18, 2010 | Casio FX-115ES Scientific Calculator
How do i multiply to 4x4 matrices using fx-991 es ?
The enclosed screen capture shows all the possible dimensions for matrices on the Casio FX-991ES. As you can see the maximum dimension of any matrix is 3. You can only create matrices with dimensions less than or equal to 3.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
How to get the inverse of a matrix an fx-991 ES calculator
Nov 02, 2010 | Casio FX-115ES Scientific Calculator
Steps to draw graphs using Fx 991 ES Plus calculator.
Good Luck!
Oct 18, 2010 | Casio FX-115ES Scientific Calculator
My calculator fx-991 Es is showing either syntax error or dimension error while finding out the inverse of the matrix although the matrix is a square one
Mar 13, 2010 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
742 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
