Question about Home
Glacier Bay Tub/Shower Facet model F1AA4217BNV
I need installation instructions for Facet
  • 10865 Answers
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Posted on Mar 18, 2010
  • 349 Answers
SOURCE: leaking form shower facet also leaking from
The face plate on your tub at handles water could be running down behind the tub when you take showers an dyou will think valves are leaking.
Make sure the face plates are tight and a gasket behind them.
Posted on May 05, 2010
  • 349 Answers
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
Posted on May 16, 2010
bloues
  • 56 Answers
SOURCE: We just bought and installed a brand new Glacier
Try to open the left hand taps head and see if maby the seal rubber isent stuck that whem u open the tap iet stays in the close posision
Posted on Jul 20, 2010
  • 152 Answers
SOURCE: I recently had a Glacier Bay single handle shower
Inside the handle assembly there is an adjustment for the anti-scald feature. If the installer left you the owners manual,it should have instructions how to adjust it. If not, have the installer come back to adjust it.
Posted on Jul 26, 2011
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
Can I get instructions to install and remove glacier bay curved shower rod. 481 010
https://www.youtube.com/watch?v=xSFWo43HN-M Don't know if this will help but it's worth a shot.
Dec 18, 2014 | Plumbing
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
My shower head comes on all the time
two possible causes. 1- make sure the valve body is installed with with shower mark on the valve body facing up. 2 - if you used pex pipe and fittings to stub out for the tub spout this will restrict the flow sending water to the shower, '' change out pex pipe and replace with copper or galvanized pipe
Apr 06, 2014 | Globe Union Glacier Bay 8 In Double Handle...
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
Installed new Glacier bay 814-278 singe handle mixing valve. In first try the valve turned on an off. After some other plmubing repairs, the same valve will not completly shut off. it dribbles some water....
If pipes were soldered for any reason after installation of the faucet valve, tiny pieces of debris could have contaminated the inside of the pipe and traveled to the cartridge and internal facet mechanism causing it to get stuck in an open position. This happened to me on a brand new tub faucet once.
Oct 12, 2010 | Home
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Home Logo
380 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
