Question about Car Audio & Video
Remove rear speakers from 1995 ford f150 extended cab
Need to remove and replace my rear speakers from 1995 Ford F150 Extended Cab. How do I get them out.
  • 2920 Answers
SOURCE: I need to replace my heater core in a 1997 ford f150 extended cab
you have to go in under the dash on the passenger side so there will be vents and stuff you have to remove. under the hood are two hoses that run to it which you also have to disconnect as these go to the heater core.
Posted on Dec 30, 2008
SOURCE: Install Rear Speakers Ford F150 1997 Regular Cab
you should not have to remove the panel by taking the four phillips screws out of the speaker grill you will pull out through front
Posted on Apr 02, 2009
mkv0525
  • 358 Answers
SOURCE: need assistance with wiring
The RH (Passenger's) side Cylinders 1, 2, 3, and 4 The LH (Driver's side) Cylinders 5, 6, 7 and 8107127755
Posted on May 27, 2009
  • 58 Answers
SOURCE: wiring code for a 1997 ford f150 xlt extended cab
1997 Ford F Series Stereo Wiring Constant 12V+ Green/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Gray/Light Blue Left Front (-) Tan/Yellow Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 6" x 8" Rear Corners Left Rear (+) Orange/Light Green Left Rear (-) Light Blue/White Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Hope this helps.
Posted on Mar 14, 2011
SOURCE: how do i replace front fuel pump on a 1995 ford f150 5.0litre extended cab dual tanks how do i remove tank
May be easier to loosen rear box bolts,remove the
front bolts & tip up the bed, rather than lay on your back
& have to drop the tank & that way you don't have the
fuel removal issue,can stand there & just work on top
of tank
Posted on Oct 07, 2012
2001 Ford F150 Extended Cab with broken frame?
replace spring mounts- cut rivets out and replace mounts(use harden bolts) have rotten frame "fish plated" by welding shop
Dec 30, 2013 | Ford F150 Ld Xl/Xlt Model W/O Lightning...
Heater fan isn't working in my 1997 ford f150 extended cab 4x4
What have you checked so far ?
Fuse - resistor - power at the blower motor ?
Feb 13, 2013 | 1997 Ford F150 Regular Cab
Problem with "open door" signal. 2006 Ford F150 extended cab. Passenger door is the affected door
i would check and see if a. the switch is loose or coming unplugged then maybe replace it!
Feb 07, 2013 | Cars & Trucks
I have a Ford 1995 Ford F150 4x4 with 5.8L and E4OD trans.My problem is a vibration occurs at approx. 60,80 and 100 kph.I have changed all wheel brgs.drive shaft,transfer box,rear end overhauled--so think...
I also have a 95 Ford F150 4x4 5.0l, extended cab two piece drive shaft. E40d trany in fourth gear accelerating or not it will vibrate badly but only slightly in any other gears. The first thing I did was rebuild the trany, no luck same exact conditions. All clutchs and bands replaced, synthic fluid, new torque converter, and a shift kit from TCI. Still does the same thing.
Nov 12, 2009 | 1995 Ford F150 Styleside Regular Cab
1998 ford f150 4.6L V8 2wheel auto, spark plug wiring diagram
you can get it online or go too auto zone and look it up in the manual
Feb 19, 2009 | 1998 Ford F150 Regular Cab
Jan 13, 2009 | 1997 Ford F150 Regular Cab
Dec 30, 2008 | 1996 Ford F150 Regular Cab
1995 Ford F150 Acceleration Issues
I THINK THEY MAY HAVE DAMAGED THE PLUG WIRE BOOTS, TAKE A LOOK AT THEM AND SEE IF THE RUBBER BOOTS ARE TORN OR DAMAGED, CHEAP TUNE-UP SHOPS ARE FAMOUS FOR CAUSING THIS KIND OF DAMAGE, THERE IS A SPECIAL TOOL TO REMOVE THE WIRES WHICH GET STUCK TO THE PLUGS, MANY YOUNG KIDS DO THE WORK BUT DON'T EVEN KNOW THE TOOL EXISTS.
Nov 05, 2008 | 1995 Ford F150 Styleside Regular Cab
Car Audio & Video Logo
205 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
