Question about ASUS DVD-E616P DVD Drive
It will not work
This has vanished from "MY COMPUTER" when I access " INTALL NEW HARDWARE" and click on it, I am told there are no drivers installed whilst under Device Manager I am told the drivers installed are up to date
Help
  • 796 Answers
Try to disconnect the power and data cable from the mother board and try to reconnect them again and also check if they are present in the bios setup
thankyou
Posted on Oct 30, 2008
Give me software to intall in computer
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jun 19, 2012 | Logitech QuickCam Communicate STX Personal...
I intall may a4 tech pc camera h driver, but cam is not working properly preview is show my image but when i select cam option in yahoo the cam showing error of no conecting plz give me solution what can i...
Oct 25, 2010 | A4tech PK-7ma Flexi Webcam
IBM thinkcentre 8183-21g voice proplem with Windows XP
Can you check to see iin your Device Manager that Hardware is Recognized and Working?
LEFT CLICK on Start, RIGHT CLICK on My Computer, LEFT CLick on Properties.
Selct Hardware Tab, Left Click DEVICE MANAGER
Are there any Items with Yellow Circles with Black ! Marks?
If there is, You need to Download the Latest Drivers
If not, I would Recommend a New Audio Card.
Hope this Helps!
Dec 20, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
This printer worked fine till windows 6 explorer was installed what happened?
You might have a Driver issue.
Usually, a driver update isused as a solution to an issue with how Windows works with a piece of hardware.
Updating a driver can also enable new or updated features for the hardware.
To access Device Manager, use any of the following methods:
  • Click Start, click Run, and then type devmgmt.msc.
  • Right-click My Computer, click Manage, and then click Device Manager.
  • Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager.
  • Type the following command at a command prompt:start devmgmt.msc
You can use Device Manager to change the way your hardware isconfigured, and to change the way your hardware interacts with yourcomputer's programs. With Device Manager, you can update device driversfor hardware installed on your computer, modify hardware settings, andtroubleshoot problems.
Device Manager enables you to:
  • Determine if the hardware on your computer is working properly.
  • Change hardware configuration settings.
  • Identify the device drivers that are loaded for each device and obtain information about each device driver.
  • Change advanced settings and properties for devices.
  • Install updated device drivers2_bing.gif.
  • Disable, enable, and uninstall devices.
  • Reinstall the previous version of a driver.
  • Identify device conflicts and manually configure resource settings.
  • Print a summary of the devices that are installed on your computer.
If the device is experiencing a problem, the type of problem isdisplayed. You might also see a problem code and number and a suggestedsolution. If you call a support line, this number can be useful fordetermining and diagnosing the problem.
How to install a new driver from Device Manager loadTOCNode(2, 'summary');
  1. Double-click the type of device you want to update or change.
  2. Right-click the specific device driver you want to update or change.
  3. Click Update Driver to open the Hardware Update Wizard. Follow the wizard instructions.
Rolling back to a previous version of a driver loadTOCNode(2, 'summary'); Use this feature if you encounter problems after you install a driver,such as error messages when you access the device, faulty behavior ofthe device, or even the inability to start Windows.
Windows XP2_bing.gif provides this roll back to a previous, working, device driver:
  1. Right-click the device for which the previous version of the driver is desired and then click Properties.
  2. Click the Drivers tab.
  3. Click Roll Back Driver.
If you cannot resolve the problem with these instructions, contact the manufacturer.
Dec 04, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have 12 Drives All 12 Drives are found but when I burn a DVD The Some drivers fail and it is not the same ones all the time
Usually, a driver update is used as a solution to an issue with how Windows works with a piece of hardware.
  • Type the following command at a command prompt: start devmgmt.msc
You can use Device Manager to change the way your hardware is configured, and to change the way your hardware interacts with your computer's programs. With Device Manager, you can update device drivers for hardware installed on your computer, modify hardware settings, and troubleshoot problems.
  • Install updated device drivers.
If the device is experiencing a problem, the type of problem is displayed. You might also see a problem code and number and a suggested solution. If you call a support line, this number can be useful for determining and diagnosing the problem.
Rolling back to a previous version of a driver loadTOCNode(2, 'summary'); Use this feature if you encounter problems after you install a driver, such as error messages when you access the device, faulty behavior of the device, or even the inability to start Windows.
Windows XP provides this roll back to a previous, working, device driver:
Dec 04, 2009 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
My speakers wont play music.
be sure that your speakers are plugged in. then right click on the tiny speaker in the lower right corner of your screen. open the mixer and turn everything on.
Sep 14, 2009 | Acer TravelMate 4010 Notebook
No sound
if u have driver disk for ur pc u must insert into ur pcs cd rom and click on start bar now click on control panel go in add new hardware wizard click on next now click on yes i have allready connected hardware choose add a new hardware device and click on intall the hardware that i mannually select from a list (advance) . now click on sound,video and games controller. click on have disk browse the driver's location and click on next or finish . good luck and enjoy
Jul 28, 2009 | EliteGroup P4VMM2 Motherboard
No sound
You must have wrong sound driver
download PCwizard and install this program will check motherboard for all your driver and list them sound driver will probably be in differnet section than main drivers note name and number of driver
EG cmedia 23415 write down and search for them on the net
cmediia 23415 drivers when found download correct drivers for your O/S.
to uninstall old driver first
go to start/control panel/system/hardware/device manager/
right click on all sound drivers go to properties and uninstall driver reboot you must do this before installing new driver
Jul 26, 2008 | Intel Motherboard
Audio and video controller
Hello.
You should look in the manufacturers website, even if you don't delete the device drivers you can visit their sites in order to find updates( this updates make you system work better, as they fix many problems and add new compatibilities to the updated ones), you might also find this device drivers for other Operating System just in case you want to intall a different one.
Most the time this software are applications, this mean that you only have to do a double click on the file or icon after downloading it.
In the case you don't know what your devices are, go to:
Start - Control Panel - Double click in - System icon - Hardware - Device Manager.
You will find the devices requiring drivers as yellow icons with the name of the device, in your case under - Sound, Video and Game Controllers.
Hope this help.
Godd luck.
Jul 11, 2008 | Microsoft Windows XP Professional for PC
ASUS DVD-E616P DVD Drive Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
