Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
Water draining out of dishwasher
After the cycles have gone through and the washing period is through, the water will not empty out. What could be causing this?
  • 71 Answers
Debris in the drain pump / clogged up drain line or kinked/ bad drain solenoid on some models
Posted on Dec 12, 2008
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
My questions relate to GE Triton DW Model GSD 6660 G00SS My problems are multiple. I have run the diagnostics and all functions seem to be working but two conditions during operation remain a...
After you the drain to discharge the remain water and the tub is visibly dry of water,then you open and load it do you see standing water after you have drained and know it was gone??
If that is the case what i believe your trouble is that where the dishwasher drain connects to disposer under the sink the drain hose is only leading from that nozzle downward,if that is so what is happening is the dishwasher is draining ok but backfilling whenever water runs through the sink. To fix that use a string on plastic zip tie and attach a portio of the drain hose so at one point the drain hose under the sink is higher that the nozzle and water in the sink will longer run into the hose and run upward since water is only going to drain down and wont ever rise on its own.The drain pump is powerful enough to push the drain water up that "HIGHLOOP" very easily.
Good luck i hope this has helped you to fix your dishwasher,
Gene
Aug 08, 2011 | Dishwashers
2LYMPAIA - F4
Hello
If you have F4 and the sump is full of water, there's a good chance the drain pump is being jammed by a broken bit of glass or pottery. However, if the appliance is empty of water and F4 error code is flashing, where do you go from there?
The electronic control (module pcb) does a self check of the components, during a drain cycle the programme allows a time parameter for the appliance to empty away the water. How does the pcb know the water has gone? Simply by testing a pressure switch for continuity.
The pressure switch is an on or off switch, when the appliance is empty the internal contacts are "made" (on) when the appliance is full of water the switch is "broken" (off).
The sensing grid of the pressure switch is exposed to the dishwasher wash water and can over a period of time get clogged with crud ( a mixture of food waste and detergent and limescale), eventually this crud stops the switch from being in the correct attitude during the self tests. The electronics notes the on or off and determines that the appiiance has not drained and gives error code F4.
If you have F4 error code it could be the pressure switch needs cleaning or replacing.
On the self test about 4 mins is allowed for the appliance to empty the water away.
Aug 03, 2011 | Whirlpool Dishwashers
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
Washing still wet after washing machine cycle. After full cycle the wahing in the machine was still soaking wet
Either the pump is not emptying the machine quickly enough, or the drum is not spinning. This could also be because there is too much water left in the machine. Check that the drain hose is not blocked and that water is draining/pumping out of the machine. A partial blockage will extend the drain period and the machine may not have time to empty the drum...Good luck......Nomess
Apr 18, 2010 | Washing Machines
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Dishwashers Logo
106 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
