Question about Sansui Televison & Video
My sansui tv sv2918 switches off after 3 seconds and it starts to flash light on the screen as if there is ashortage some way . please help
My tv a sansui sv2918 switches off after every 3 seconds . It actually counts the 3 seconds on the screen. Please help.
  • 1694 Answers
SOURCE: Sansui SV2918 has no picture and audio only a blue screen
Have you tried the a / v inputs?? If they work,might be a bad tuner.If they don't work,then your symptom is no video-no audio=
power supply problem? Check all voltages....T.
Posted on Oct 25, 2007
wyoed1
  • 211 Answers
SOURCE: philips tv chassis L9.2A
The flashing LED is an indication code of a board problem. If the TV is shutting down after a very short period of time, it is an indication the something is heating up. To isolate the problem, you will need to purchase some freeze spray ( component cooler ) at your local electronic shop. turn the tv on and spray an area ( usall about 1/4 of the board at a time ) and try to isolate the bad part ( component ). By repeating this process after a bit of time, you should find the part thats bad when you cool the part and the set stays on until the part heats up again. Then simply replace the part and your good to go. Always use precautions when working inside a tv as the picture tube can have as much as 35,000 volts on it ( can cause bodly harm or death ). DON'T COME IN CONTACT WITH THE WIRE OR GET CLOSE.
Good luck and I hope this has helped
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 24, 2008
  • 6 Answers
SOURCE: TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
Posted on Apr 08, 2008
SOURCE: sansui tv sv2918
Sweetch on thr tv just one vertical line comming in center of ty screen
Posted on Jun 20, 2008
  • 979 Answers
SOURCE: Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
Posted on Jul 10, 2009
My Sansui SV2918 has vertical collapse and no sound.Please help.
Sansui.. Funai made?? Most Funai sets are identical. Find a diagram for a similar TV. Or.. Google the part# of the output IC. The datasheet should contain application data, including a basic schematic of the vertical cicuit.
May 19, 2014 | Televison & Video
Hi i have a sharp aquos lc-37d43u tv and I can't get it to connect to my computer .I tried HDMI and VGA but I just don't seems to understand how to make it work ;( Please HELP
prob with sansui sty 0330 LCD TV
hi,i have a sansui sty 0330 tv and the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Dec 18, 2013 | Sharp Aquos LC-37D43U 37 in. LCD HDTV
Sansui sv2918 keeps blowing k2996 mosfet. Power led flashes and ta-ta-ta sound is heard
Check the Flyback Transformer
and associated circuits.
If 2SK2996 is blown, it may take out the PWM IC and some components
that goes with it.
Let me know what you find or needs further assistance.
Sep 17, 2012 | SansuiM1315 TV
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
May 31, 2012 | Samsung Televison & Video
When I switch tv on at button on tv I van hear the tv goes on. No Picture. If I press buttonds on the remote I can see the red light come on that indicate the remote is sending signal. Here comes the best...
Replace , front panel switches , one or more switches goes high resistance
when suppose to be open circuit , my sv2918 74cm was doing weird things
with these switches going bad
May 10, 2011 | Sansui D 27" TV275 TV
Hi I live in Kempton Park South Africa and my Sansui TV Model SV2918 does not swith on. The product is very good and I would like it to b repaired. Do you have suggested maintenance people that I coul
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
May 25, 2009 | Televison & Video
Faulty line stage sv2918 sansui tv
Can you please post the make and model. That would help u sto provide you with more details.
Thanks,
Dan
Dec 01, 2008 | Televison & Video
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Jun 18, 2008 | SansuiM1315 TV
Dec 03, 2007 | SansuiM1315 TV
Televison & Video Logo
19 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
