Question about Brother HL-2070N Laser Printer
Brother lc1100hy printer offline can't get it to go online
SOURCE: printer online then offline
Had the same problem with my mother's MFC and after 4 hours of troubleshooting I fixed it.
My mother's printer was networked through the router. Here was the solution.
1. Go to printers and faxes.
2. Right click and go to properties.
3. Go to ports (for some reason its shows Brother PC-Fax v2)
4. Add new port.
5. Enter the IP address (check the printer menu to find the IP Address ie. 192.168.002.002. To be safe enter 002 instead of 2.)
6. Restart the computer.
Wait a minute or 2 after restart and the printer should now be online.
Hope this helps you guys.
Posted on Mar 04, 2008
rylee_smith
  • 8619 Answers
SOURCE: printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: Brother HL-2170W Laser Printer is 'offline" wpm
Is this the initial install? If so do this.. I finally figured this out. Do the "cable" install. After it discovers the printer etc you will get to a screen during the driver part of the install that will ask you how to find the printer. The "recommended" list method is a deadend!  Instead, check the IP address option and input that.. You can get the IP address of the printer from the test page which should have already printed.(Its probably 192.168.2.3).  I run   XP and it solved the problem. I suspect its also the answer for Macs and Vista as well.
I have also had success by doing the "cable" install, then when its done, deleting the printer in Printers and Faxes, then doing a manual install (you still need the IP address).  I am using two computers to go to this printer and it flies. Great speed.
Posted on Jan 22, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
bschilz
  • 2049 Answers
SOURCE: Brother HL-4040CN successfully installed but shows offline
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Posted on Sep 17, 2009
How to turn printer from offline to online
Often times the printer will show being offline if the computer wasn't turned on before the printer. Also, if you have more than one printer be sure the printer you are trying to use is selected in the printer setup page.
Aug 16, 2017 | Brother MFC 7860DW - Multifunction fax /...
My brotehr mfc-9320cw printer will not print..it says it is offline how to I reset it to online?
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 05, 2011 | Brother MFC 490cw Color Inkjet...
My brother 4040CN printer is on a offline mode how do i set it to online mode?
Hello, Open the start menu and click on the "printers and faxes" icon. This will open a window with the list of printers currently set up on your computers.
2. Double click on the icon of the printer you want to change to online. A pop-up window detailing all current print job will open.
3. Go to printer in the menu bar of the pop-up window and unchecked "use printer offline". This action will change the printer from offline to online mode.
Thanks
Jun 29, 2011 | Brother HL-4040CN Laser Printer
When I try to print I get the message " Printer
Check the following steps to fix printer offline error :
May 04, 2011 | Brother MFC-490cw All-In-One Inkjet...
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
Brother Printer Offline
Apr 12, 2011 | Office Equipment & Supplies
Why does my Brother printer goes into Sleep mode and I can't print??
I have copied in the illustrated instructions for resolving printer status is Offline or Paused. (For Windows®) but if distorted please view here.
The printer status is Offline or Paused. (For Windows®)
Description:
To solve the problem, please see the following:
  • If the printer status is Offline:
    Check that the printer is online using the following steps:
    VERIFY THE BROTHER MACHINE IS POWERD ON AND THERE ARE NO ERRORS
    1. If the LCD screen is blank, then the Brother machine is not powerd on the machine to see if it wakes from sleep mode. If it does not, then verify that it is plugged into a working outlet and any power switches are turned to the ON position.
    2. Check the LCD screen for any error messages. An example would be "Paper Jam" or Ink/Toner Empty". If the LCD screen shows an error troubleshoot to clear the isssue indicated.
    CHECK THE PRINTER STATUS
    NOTE : These steps or screens may differ depending on the operating system.
    1. For Windows® XP Users:
      Click Start => Printers and Faxes
      For Windows Vista® Users:
      Click Start => Control Panel => Hardware and Sound => Printers
      For Windows® 7 Users:
      Click Start => Devices and Printers
    2. For Windows® XP and Windows Vista® Users:
      Right click on the icon for your Brother machine and choose Use Printer Online.
      Double click on the icon for your Brother machine => See what's printing => Printer => Use Printer Offline (Take the checkmark off.)
Note If the problem still continues, do one of the following:
  • If you find the Related FAQ's at the end of the page, click it and check another solution.
  • If you don't find the Related FAQ's, please contact Brother Customer Service from "Contact Us".
  • If the printer status is Paused:
    Right click on the icon for your Brother machine and choose Resume Printing. (If the menu reads Pause Printing, there is no problem in the printer status.)
    Double click on the icon for your Brother machine => See what's printing => Printer => Pause Printing (Take the checkmark off.)
    If this does not solve the problem,
    Double click on the icon for your Brother machine and choose Printer => Cancel All Documents.
    Double click on the icon for your Brother machine => See what's printing => Printer => Cancel All Documents
If you are using Windows Vista or Windows 7 please view here.
Trust this is helpful.
Dec 17, 2010 | Brother MFC 7840W Printer
My Brother HL-5250DN is shown as offline. I am using Windows 7 and a 64-bit machine.
Open the "Printers" window.
Click with the SECOND (usually the RIGHT) mouse-button on the printer.
Click to "go online" or "use online" or click to disable the "offline" status.
Dec 29, 2009 | Brother HL 5250DN Laser Printer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
Brother HL-2070N Laser Printer Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
