Question about Whirlpool LER5636P Electric Dryer
Where is the thermostat on a whirlpool awz 220 dryer
Front loading electric dryer
  • 3 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
You can usually download from Whirlpool website
Posted on Jul 10, 2008
SOURCE: whirlpool electric dryer not heating
I had the same problem today. After stumbling through the schematics (they were taped up behind the main control panel on top of the dryer) and ohming out a bunch of different parts with my multimeter, I finally took the heater element out and found that it had burned in two in a spot (I could see it once I took the element off of the dryer). I replaced it for about $80. The guy at the parts store said that is usually caused by a clogged vent, which is probably the case for mine, since my vent is poorly designed. I hope this helps someone.
Posted on Jan 18, 2009
  • 124 Answers
SOURCE: replaced high temp sensor on whirlpool front loader
Hi, Here is what is happening.
  1. Yeah fixed it by replacing hi temp sensor.
  2. Then sensor went out again.
  3. Reason there is another sensor that controls heating element. One is high temp, which controls the heating element from overheating. The other controls normal heating element temp range. What normally happens is the temp range goes out & heating elements overload the high temp sensor causing it to fail. Usually best to replace as pairs. Make sure your using the proper temp sensors as well. If you get temp range hotter than high temp results same problem.
Hope this cleared up your problem & fixed you for good. Please rate. Good Luck! If I can Help further please send comment.
Posted on Mar 13, 2009
SOURCE: whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Posted on May 31, 2009
  • 903 Answers
SOURCE: where can i get a manual for whirlpool awz 220
Hi, you can find the AWZ 220 manual at NoDevice.com, e-ServiceManuals.com, or Manuals-In-PDF.com. (You'll probably have to pay a small fee to download it.)
Posted on Sep 20, 2010
Trying to get the service Manual for awz 3477 whirlpool dryer. The heating element goes on but after about 5 minutes it turns off + lint light goes on. Have cleaned the traps. thinking thermostat?
Have you cleaned the sensor bar? Did you remove the grates and clean out the lint traps, not the filter the actual traps? Does it have any codes stored? Most modern dryers can give error codes (even ones without a display)
Oct 13, 2016 | Whirlpool Dryers
WHIRLPOOL AWZ 410-1000 parts
I bought before through Ebay , might get it cheaper there though .
Just make sure you got the right part number :) and search it ..
Regards,
Feb 19, 2013 | Whirlpool AWZ410 Front Load Washer/Dryer
Where can i get a manual for whirlpool awz 220
Sep 20, 2010 | Whirlpool Dryers
Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Mar 20, 2010 | Whirlpool Dryers
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
A FELT STRIP CAME OUT OF MY DRYER. CAN I STILL USE
you need to reinstall it because that is what the drum glides on and in time you will hear metal on metal grinding
Sep 28, 2009 | Whirlpool LEW0050P Dryer
Whirlpool AWZ412 No Instruction Manual - Dryer
https://www.2instructions.com/search.php?cmarque=WHIRLPOOL&modele=AWZ%20412-1250
Sir, go there and fill the related blanks and order online. EX:- Fill the description with " Front Load Washer " and E-mail section with your E-mail address. Thank you.
Sep 18, 2009 | Whirlpool AWZ412 Front Load Washer
Whirlpool LER5636P Electric Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
