Question about Health & Beauty
My visocor om 40 boodpressure meter does not want to inflate the cuff
SOURCE: The Sunbeam blood pressure kit doesn't inflate the cuff.
You have the same problem I do. The hose socket to the machine is broken.
Posted on Sep 06, 2010
SEGlover
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
  • 54 Answers
SOURCE: Cuff won't inflate
It probably has a leak. Examine the hose and cuff for cracks by flexing it , especially at the fitting where the hose attaches to the monitor. Also check where the hose attaches to the cuff. Try replacing the cuff.
Hope it helps. Please let me know.
Thanks
Posted on Apr 27, 2010
  • 23 Answers
SOURCE: Cuff does not inflate properly. Blows up like a
I think your BPM machine has some problems in the electronic components it might not due to the cuff. Shoud return to the shop when you bought it from.
Posted on Jan 11, 2011
Testimonial: "Thanks for your advice................makes a lot of sense."
  • 23 Answers
SOURCE: wrist cuff fails to inflate
1. either the wrist cuff connection to the unit is not connect properly. OR 2. the motor pump is not working OR 3. the air tubing inside the wrist type BPM has leakage.
return to the shops for a new one.
What`s the red yellow green lines left on the screen
Looks like it's the cuff inflation meter. Go here for more info -https://www.andonline.com/uploads/documents/I-UA-767PV_0409.pdf
This is the manual for the UA-767 plus
Sep 28, 2014 | Lifesource UA 767 Plus Digital Blood...
Why does anOmron M7 Blood Pressure Monitor Cuff not fully inflate?
I have the BP760 model so I'm not entirely sure what the functionality differences would be. However from time to time I have had issues with the cuff not inflating. It is usually one of two things: the cuff is not positioned snugly enough on the arm (I have a skinny arm and sometimes need to enlist the help of a family member). The other time it has happened was when the inflation tube itself with so kinked and twisted that air could not flow through. You should also check to make sure that the inflation tube in securely connected to the unit. So make sure that the air supply from the cuff to the unit is not obstructed, and that the arm cuff is positioned properly and that you are not trying to put the cuff on over clothing. If you've checked all of this and/or you receive the error message of "Er", you should contact customer service. Hope this helps.
Aug 29, 2014 | Health & Beauty
I have a blood pressure sphygmomanometer, how do you take a blood pressure reading and what is normal?
Much easier to go to a store, like Walgreens and get an inexpensive ( like 15 dollars) automatic wrist cuff blood pressure monitor, that will give you accurate and quick readings of your heart rate, and blood pressure, systolic and diastolic, automatically.
Apr 03, 2011 | Walgreens Health & Beauty
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Cuff won't inflate
Thanks
Apr 22, 2010 | Mabis Automatic Digital Blood Pressure...
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Health & Beauty Logo
388 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
