Question about LG KU990 Viewty
Unable to connect LG Viewty to PC via USB
Currently, not able to connect LG Viewty with PC. The phone is recognised but then get a message phone not connected. Was able to do once before.
  • Anonymous Dec 10, 2008
    help me! My phone is connected into the computer and the disc is in too but it still says failed to connect
    PLEASE HELP
  • Anonymous Apr 08, 2009
    what if i dont have a memory card? i've uploaded software but its still not working xx
  • 275 Answers
Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo....
  • 2.Select setting
  • Press Mass storage
  • Press OK.
  • 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
    Posted on Dec 09, 2008
    Make sure you double-check "Multitasking" (touch the image of squares in the upper right corner) and see that nothing is open but "Home Screen" and "Menu."  If you have anything else running, your USB connection won't work.
    Posted on Feb 05, 2009
    LG viewty - using windows 7 on pc - unable to find my phone when connected via USB
    I have this PC Suite, It works fine with my wife's KF750. Not sure whether it is device specific or not, though. Give it a try, if you really want.
    Regards, Carlos
    May 28, 2010 | LG KU990 Viewty
    Can not down load from pc using usb cable
    what's the brand of the phone? normally every brand has its own way of connecting to the computer. nokia for instance uses nokia pc suite as a sync application. normally a cd with compatible software is delivered with the phone. if you don't have the cd, you can download the soft from the manufacturer's web site. install this software first and wait for the soft installer to ask you to connect the phone at the right moment to make a valid synced connection between the pc and the phone...
    Apr 21, 2010 | LG KU990 Viewty
    I need to upload photos and videos onto my pc, how do i do it?
    u must hav got a usb cable with the phone... connect the phone to pc using the cable..... ur pc will show new device found...go to my computer..removable devices..browse ur phone memory card and copy the files from..
    if u dont hav a usb cable u can use a blutooth device also...
    Apr 16, 2010 | LG KU990 Viewty
    Computer doesn't seem to recognise LG KU990i via usb
    first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
    Aug 08, 2009 | LG KU990 Viewty
    Cannot connect my LG Viewty to the computer via the LG PC suite
    hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
    Apr 13, 2009 | LG KU990 Viewty
    Unable to import messages from message manager
    Unfortunately it is a flaw with the PC suite and there's no way around it. There is currently no official solution for this but if you search www.ku990.co.uk there are help pages in the forums explaining how to transfer your messages and emails from the phone, albeit they are very complex, time consuming and often unreliable third party methods that are more than likely to break the data than store it. Sorry people.
    Feb 08, 2009 | LG KU990 Viewty
    Usb connection drops out
    Download this USB driver for the Viewty:
    LG KU990 viewty firmware download:
    LG KU990 - V10a - 05-11-2007
    Now your PC will 'recognise' it as a Viewty and not just as an 'Unknown Device'.
    Hope this helps!
    Chris (ziraffa)
    ps that firmware is stored at megaupload, so if you're not registered with that site, just wait the 60 seconds or so to begin download.. No sense in 'paying' for access to free drivers!
    Dec 26, 2008 | LG KU990 Viewty
    LG Viewty pc connection problems
    What you need to do is click on the top right corner of your LG Viewty phone which will show all applications running. If you have an 'Unknown' app, click on this.
    The problem is that the user guide for the phone is running and you need to click on 'Unknown' and finish the tour or exit.
    This will then alow you to connect to your pc;-)
    Dec 22, 2007 | Cell Phones
    LG KU990 Viewty Logo
    2,289 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
