Question about Konica Minolta DiMAGE G530 Digital Camera
Will not turn on even with charged battery
Camera's indicator lamp light blinks indicating insufficient power for camera operation, however, I have fully charged the battery and then when I turn the camera on the indicator light dosen't blink anymore. I tried a friends battery (we have the same camera) and it works in his camera but not mine. I let the battery charge over night and had it in the camera for a while and when I went to check the camera it felt really really warm to touch so I took the battery out and it cooled down. I have had the camera for 1 1/2 years and this is the first time I have had a problem. Please tell me it can be fixed. Thanks.
  • ONuallain Apr 29, 2009
    Have same problem. New battery Charged. Open sliding shutter to turn on camera bur lens will not come out and camera can't operate. Then when I close the sliding shutter a green light come on and of near viewer. Have had this camera for several years and used it a lot. Great easy to use camera with wonderful results. Any ideas please?
The same thing happened to me. Your battery clip (the thing that holds your battery in) has probably fallen out. Put in a small piece of folded up paper on top of it and close the slider. This will hold down your battery. Turn on your camera and it should be fine. Hope this helped! :)
Posted on Nov 20, 2011
Iam trying to tern on my camera konica minolta dimage 530 . but not succseed and always red color terun on and off with out stoped near the licens and up the screen always yelow lamp turn on always and off can u help thanks
Posted on Jan 01, 2008
    Genius:
  • 2,985 Answers
If your friends battert worked in his camera but not in yours,That is what you said wasn't it? Then it is not a lack of power. But a camera prolem. The only likely fix is to replace it. But check the makers web site first.
Posted on Aug 03, 2007
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
Not powering on
The manual indicates that the green light flashing once indicates that the camera is powering down.
http://www.manualnguide.com/dl/6597/ (see page 218 lamp indications)
The first thing you can try is to turn off the camera, remove the battery, remove the memory card. Hold for one minute , pop the battery in(but not the memory card) turn on the camera by pressing the power on buttn and holding it for 15 seconds. This will not only reset the camera but also force the motor to retrace/extend the lens if it is a lens related issue that is causing the camera to shut down.
Let me know if you need more help
Jun 04, 2017 | Casio Exilim EXZ75 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Camera won't turn on ...just there is red lamp is workoing
Here is the link to the user manual for your camera if you need it; ftp://213.61.96.30/camera%2fmanuals%2fdc_c500%2fdc_c500_um-english-cd-0822.pdf The red lamp, if it is flashing/blinking indicates that the self-timer function is on - check page 15 for how to turn it off. If the light is steadily on, and it is the battery/power status light, then the indication is that the battery is faulty or not charged - possibly the fault is with the charger, but more likely a new battery will solve the problem. To get a new battery, go to; http://support.BenQ.com and they should tell you where you can get one, if no luck with them, please post back with which part of Egypt you are in, and i can try to find you a dealer locally. Hope this helps :)
Apr 11, 2007 | BenQ DC C500 Digital Camera
Nikon Coolpix S2 green lamp
Check the PDF manual on the software disk to be sure Nikon Technical Support for confirmation- this is a possible replacement situation
Feb 16, 2007 | Nikon CoolPix S2 Digital Camera
Wont speed up even with new batterys
The shutter button features a two-stage action. shutter_button.gif Pressing Halfway Pressing halfway automatically sets the exposure, focus and white balance.
The indicators light or blink as follows.
Upper Indicator
" Green: Metering complete (two beeps sound)
" Orange: Flash will fire
" Blinking Orange: Camera shake warning / Insufficient exposure
Lower Indicator
" Yellow: Macro Mode / Manual Focus
" Blinking Yellow: Focusing difficulty* (single beep sounds)
* When the indicator blinks yellow, lock the focus before shooting.
Sep 24, 2006 | Canon PowerShot A400 Digital Camera
Even when I immediately switch power source (AC adapter or External Battery Pack) right after the low-battery icon started to blink, the camera operation is still locked.
In cases where the blinking low-battery icon appears indicating insufficient power, wait approximately 8 seconds until the LCD monitor display and the EVF become blank. Then switch to another power source or replace with fresh batteries.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Konica Minolta DiMAGE G530 Digital Camera Logo
187 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
