Question about Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One ZE6 - Screen remains blank
When it first happenned on turning on the netbook, I could hear the netbook motor running and the lights turned on, but no screen. I tried Cntrl-Alt-Del and also F2 on powering on but nothing happens. The screen stays dark. Now the motor sound also does not come up. Only power on lights work. Pls help.
sandrew
  • 2961 Answers
SOURCE: i can't "wake" my aspire 3628 ANWXCi from standby
Go to the Acer website and download latest e manager software drivers, they may be corrupt. http://www.acer.co.uk/acereuro/page74.do?UserCtxParam=0&GroupCtxParam=0&dctx1=17&CountryISOCtxParam=UK&LanguageISOCtxParam=en&crc=2553782219
Posted on Jan 15, 2007
  • 17 Answers
SOURCE: bootmgr is compressed
I know of three solutions, none of them will work without recovery or OS discs, and I can only guarantee one of them--the one that whipes your system. Try these in this order (assuming you have system discs);
#1 Boot from the system disc and choose the "repair" option. This is the quickest fix, and you lose anything.
#2 Boot from the system disc, and in your Start menu search type "Command Prompt". Open Command Prompt and type (hit enter after each line);
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
#3 Run a full system recovery from your system discs.
Now, if you don't have your system discs, and you're running Windows Vista, there is another possible option. If your computer is fairly new then you probably have a WinRE partition for recovery, (a "factory image" drive)? I won't go into this now, if you have your discs option 1 or 2 should work for you.
Posted on Feb 27, 2009
belloso2
  • 71 Answers
SOURCE: My Acer Aspire one Netbook XP(SP3)'s system recovery doesn't work
Are you trying to access your original recovery software the one that is located on a separate partition? If you are and aren't able to, that particular partion might be currupted. your only option would be to try to install your software with a disc.
I hope this helps.
Posted on Apr 10, 2009
rockitman187
  • 2559 Answers
SOURCE: I have acer aspire trying reinstall windows xp?
Put the disk in,restart computer and tap F12 while it is starting up.
Posted on May 06, 2009
leecom72
  • 4806 Answers
SOURCE: i get ntldr is missing on my netbook, help in simpliest of terms
Pressing Ctrl, Alt and Del just restarts the computer.
"ntldr" is a windows boot file which has become corrupt and unreadable causing the computer to loop on boot up.
As far as i know that laptop does not have a CD/DVD drive so you can't fix the problem unless you have a external CD/DVD drive and a recovery CD.
Is the netbook still under warranty? If so take advantage of that and send it in for Acer to deal with.
If not you will need a recovery CD or Windows install disk, an external hard drive and some patience.
If you need anymore help or advice please post back.
Good luck.
Posted on Aug 18, 2009
Acer Aspire One NAV50 screen blank
I am not in a position to offer free remote help, but you might help yourself with the link (below). It's to Acer's online community.
If this helps, you can indicate as much - g'luck.
http://community.acer.com/t5/2013-Archives/Acer-aspire-one-model-nav50-Drivers/m-p/57977#M39399
Jun 28, 2017 | Acer Aspire One Netbook
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 07, 2012 | Acer Aspire One Netbook
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Screen not working power coming on but screen remaining blank acer aspire one notebook
did you connect external desktop?  when you switch the led is on. tell  me more information
Mar 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
Screen remains blank when netbook is turned on
I think again this problem on this laptops, data cable Lcd, have to repair or changed, u have to send any technician
Sep 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Blank screen...no keys working
Hi
is the acer still covered by the warranty? you can get it repaired for free if it is, its a common fault with these, my friend over here in finland has one of those and it did the same thing, he got it replaced / fixed for free since it was under warranty. get yours fixed also.
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
You broke it! Try re-installing OS software, hoping you still have the CD disk.
May 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
My Acer Aspire one won't turn on.
I also have this problem with my Acer netbook.  I have only had it for 4 months and am in Turkey on an extended break at the moment.  I have taken the netbook to a dealer here and have been told the problem is the motherboard, verified by Acer themselves.  I am not happy with this as the netbook was not cheap and there appears to be a few Acer models with the same problem
Feb 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
501 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
