Question about Philips CD6451B/05 Phone
Philips CD6451B/37 Cordless phone w/Answering machine-NO BASE FOUND-SEARCHING
This phone powers on but it seems like handset cannot find the base- it displays message"searching, searching - NO BASE FOUND" and of course, there is no dial tone. I called Philips cust svce and did reset etc- but it didn't help. This phone is not under warranty since I bought it on eBay. DOes anybody know how I can fix this problem?
Try changing the battery. Try using a new AAA rechargeable battries.
Posted on Apr 02, 2009
  • josefer26 Apr 02, 2009
    Try going again through he process or registering the handset to the base as per the manual. Also ensure the base station is atleast a metre away from electronics.
Trying to register my CL84252 at&t handsets to the base but the handsets keeps displaying an error message "out of range or no pwr to base"
Check to make sure the base station does have power. If it does have power the base station is defective or the handset is the problem (systems with just one handset), if all handsets display the same error then it is the base.
Nov 03, 2016 | AT&T Lands Phones
Why does screen indicate "searching"?
The handset cannot communicate with its base.
When the handset cannot establish its secure (encrypted) radio
link with the base it is 'paired with' or 'registered' to, it will first
say "Connecting....", then it will display "Out of Range or No
Power at Base", then it settles at the infamous "Searching..."
display.
Although rare, the registration between base and handset can
become corrupted and lost so that we must de-register and
then re-register the pair.
First, ensure that power is 'on' at the base (a more common cause)
and the cradle will charge the handset, etc.
Second, be sure the handset battery is well charged as a weak battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
or it will display "Registration Failed"
Mar 20, 2016 | Uniden DECT 6.0 Cordless Phone
There is a message "Searching" on the phone, How do I get it back to working.
You might try to de-register the handset and re-register
it to the base. Be sure the handset's battery is well
charged, a weak battery can impede the registration.
( I ) To de-register the errant handset:
1. Press and hold the [END] and [ # ] keys at the same time until the screen displays
2. press [select]
3. scroll to "Base Unavailable"
4. press [select]
5. display says "Not Registered"
( II ) To register the handset to the base:
1. open the base display's [menu]
2. scroll to "Register Accy."
3. press [select]
4. on the handset, press and hold [ # ] until
the handset display says "Registering"
5. In ~30 seconds, handset display will say
"Registration Complete" or
"Registration Failed".
This is described on page 22 of the manual.
A free copy of the User's Manual can be obtained
at www.manualslib.com .
Jan 15, 2016 | Uniden D16883 Phone
Philips cordless phone se 455
CANON IR2520 ERROR E000000
Nov 11, 2013 | Lands Phones
The handset has out of range or no power at base, how do I fix?
I found this solution in a Amazon customer review!! Worked right away in 2 seconds! Punch in *331734#MenuSelect (including the asterisk and the hash mark). Good Luck.
Feb 28, 2012 | AT&T DECT 6.0 Cordless Phone System with...
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
I put new batteries in my At&T cordless phones and I am getting a message on phone screen T23 PD
To register a handset to your telephone base
Make sure the handset battery is installed and charged properly. You have to enter a 15-digit telephone base ID to register the handset to the telephone base.
To find the telephone base ID and register the handset:
1. On the telephone base, press the MENU softkey when in idle mode to enter the feature menu. Press the or softkey to scroll to the DISPLAY BASE-ID menu, then press the OK softkey. The telephone base ID will be displayed.
2. On the handset, use the keypad buttons to enter the telephone base ID and press the OK softkey.
Press the softkey to move the cursor.
3. The handset will first display PLEASE WAIT!!, then T23 PD followed by SEARCHING FOR BASE. The screen will finally display HANDSET X when the registration is successful.
NOTES:
1. If the registration is not successful, the display will show NO BASE SUBSCRIPTION. Try the registration process again.
2. If an incorrect base ID is entered, the base ID will disappear and ENTER BASE ID will be displayed.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Cell Phones
Load default Delta file message
Problem My handset displays either LOAD DELTA FILE or LOAD DEFAULT DELTA FILE. What should I do?
Solution(s) Tip 1 of 2
If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system:
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
Nov 16, 2009 | AT&T 650530003417 Cordless Phone
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Jul 11, 2009 | Lands Phones
Philips CD6451B/05 Phone Logo
541 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
