SAMSUNG BD-D8900 HELLO MESSAGE - Televison & Video
Can't connect Samsung bd-e5400 to network
put in network password and had an "unable to connect" message, turned the bluray player off and on again and then the network connection worked fine. I had to also switched to "manual", failed to manually assign an IP, then switched back to auto. 1 of those 2 things solved my problem.
Dec 25, 2012 | Samsung BD-E5400/ZA BLURAY PLAYER BD WISE...
Hi there. I have a sky hd plus box and I am unsure how to connect it to my Samsung BD-D8900 Blu-ray HDD player so i can record programs from the Sky box. Hod do I do this please?
Connect the Sky boxes AV out to the line in of the Samsung using a Yellow/Red/White RCA cable. Then in the source button of the Samsung choose External In or Line In and just hit the record button. The only problem with this connection is that you will have to leave the Samsung selector on Line In even just to watch programs from Sky. This is called a looped through connection. Your Sky is looped through your Samsung Recorder.
Sep 11, 2011 | Samsung BDD6500 Bluray 3D Player
I have a samsung bdp1500 and it will now not play discs, the display says "no disc" all the time, even after a reset??
hello,
First think you should do is clean your BD pickup with a pick up cleaner. If it still not working, call samsung technician to check it.
Apr 11, 2011 | Samsung BD-P1500 Blu-Ray Player
Hi, I have a Samsung Blu-Ray BD-C5900 and I it does not play all regions DVD's, I would like to play all regions on m Blu-Ray, is there a code that can set this up?
Turn your BD on without cd in it, wait until appear no disk on screen.
Use this combination : Repeat-5-6-7-3-2-9
You should seen "9" on right of screen.
Good luck.
Apr 01, 2011 | Samsung BD-C5900 Blu-ray 3D Player
DVD player Samsung BD-P4600 how to make it multi-code
Hi.
Try the following region hack procedures.
1. Turn on the player with no disk inside.
2. Wait for the no disc message.
3. Press REPEAT 57538.
4. The number 2 will display in the top left corner
5. Press 9 to select multiregion.
6. The Samsung BD-P4600 is now region free.
It works on most Samsung BD-P4600 .
Dec 30, 2009 | Televison & Video
My samsung bdp1000 wont play blu ray discs
I DOn't know the answer BUT the Samsung site has firware updates which might help you. Take a look:
http://www.samsung.com/us/function/search/resultList.do?searchWord=BD-P1000
Make sure you copy the entire link. I hope this helps. Let me know
Mar 31, 2008 | Samsung BD-P1000
Televison & Video Logo
146 people viewed this question
Top Televison & Video Experts
