Windows xp is not turnoff
When i press start turnoff my computer turnoff then it is not shutting down
    Problem Solver:
  • 7 Answers
It seems that ur virtual memory is low or ur windows is corrupted. obtain new copy of windows. another way is to wait 5min if u can
Posted on Jul 24, 2009
Safe mode on a computer
When you start the PC, as soon as it hums up start hitting F8 button. The black window with a bunch of safe mode options will show up, select the one you need.
Aug 27, 2014 | Microsoft Windows XP Home Edition
Tip
HIBERNATION
THE OPERATING SYSTEMS WHICH THE MICROSOFT HAVE PRESENTED TO US HAVE MANY ADVANTAGES AND NOW I AM SHARING ONE WITH YOU FRIENDS.
WHEN WE ARE DOING A TASK,IF WE WANT TO GO FOR ANOTHER WORK LEAVING THE COMPUTER ALONE,WE USUALLY SAVE THE WORK AND SHUTDOWN THE SYSTEM AND GO FOR THE NEW WORK.BY A SIMPLE TECHNIQUE THIS CAN BE AVOIDED AND WE CAN REENTER INTO THE WORK WHICH WE WHERE DOING BEFORE SHUTDOWN.THIS FEATURE IS CALLED HIBERNATION.THE STEPS TO DO THIS IS THE FOLLOWING.
1.Click Start
2.Select Settings-Control panel- Power options-Hibernate- Enable hibernation.
3.The system can be left to hibernate by selecting the turnoff option,then point the mouse to the stand by option and by pressing down the shift key,select it,then you can see the option as hibernate and select it.Then you can see instead of shutting down windows,it gives the message as hibernating.Then it is ready,then you can return to the work by again pressing the main power switch of the CPU.Try it and look how amazing it is.
WARNING:First go for a trial with open windows(2 or 3......) and then try in actual practice.Does not cause any failure to the system 100% safe operation.Thank you
on Dec 28, 2008 | Microsoft Windows XP Home Edition
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
The PC is not shutting down
It could ofcourse be a virus, so I'd recommend a system restore back to before that happened. If that doesn't help load a backup or do a clean install.
Could also be the power connector on your motherboard is shorting with the reset connector (they're right next to each other) Maybe you'd check that first, before the clean install. Don't know if that mobo has a reset button though. They're usually in the right bottom corner of the mobo, together with all the other front panel connectors. Maybe you could insulate the power and reset buttons?
Else you could always buy socket with an off/off switch, and connect the PC to that. Just shutting it down and than turning off the socket when the reboot starts won't hurt the PC.
Dec 09, 2009 | Intel D845GVSR Motherboard
Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
Dec 01, 2009 | Microsoft Windows XP Professional With...
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Windows shut down unexpectedly, and when I rebooted, I had lost all my icons, and start tool bar. How to get them back?
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" width="15" border="0" height="21" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.take care god bless
May 06, 2009 | Computers & Internet
Windows XP professional loop
Glad to hear you have your OS disc handy... let's try this:
Insert your XP CD and when it asks if you want to boot from the CD, press any key (ENTER) to do so. When asked, press ENTER ("To setup Windows XP now") and follow these steps...
To repair a Windows XP installation using Recovery Console, press "R"
To quit Setup without installing Windows XP, press "F3".
Press Enter to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console". You Do Not want to load the Recovery Console.
Select the XP installation you want to repair from the list and press "R" to start the repair.
((Note: If Repair is not one of the options, END setup. After the reboot read Warning#2! ))
Setup will copy the necessary files to the hard drive and at some point the system will reboot. When this happens, you want to now allow the system to boot from the hard disk but leave the CD in the drive. So do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Hope that helps.
Sep 09, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
