Question about HEWLETT-PACKARD ProBook Computers & Internet
Hp probook 4710's very dim screen. Does it have an inverter
Does this laptop have an inverter? I get a very dim image from the screen. I can see this dim image with a flash light. I have changed the screen twice thinking it may be defective. An external screen does work on this 4710s. Any suggestions? I am puzzeled.Any suggestions? Anyone? Thank you........Rick
  • 317 Answers
SOURCE: backlight or inverter
That would be the backlight. If it were an inverter issue then you wouldn't have any video at all.
http://www.fonerbooks.com/laptop_5.htm
Posted on Jan 13, 2008
Bat1956
  • 585 Answers
SOURCE: LCD dim.
If you have replaced the screen and the inverter, about the only thing left is the flexible cable from the monitor to the video card. I take it that the Fn+F8 makes no difference?
Posted on May 23, 2009
  • 57 Answers
SOURCE: HP DV1000 screen too dim
The 4 most common problems with dim lcd's on a laptop are boken screens, bad power inverter, bad florescent bulbs or a broken cable.
You can test the power inverter with a meter.
There should be 2 bulbs. If your screen is dim and your inverter is good and you can still make out what is on the screen, you probably have a bad bulb. If you can't determine which bulb is bad you'll have to replace both.
In my opinion, the easiest way to handle this is to replace the whole screen. Yes, it's more exspensive, but consider that it is most likely to fix your problem. A replacement screen comes with the power inverter, both bulbs, and the cable; already assembled and ready to install.
Posted on Mar 06, 2010
SOURCE: Turning on volume on HP
if u r using a linux operating system For sound to work you will need to add the following Linux to your /etc/modprobe.conf (or your distro's equivalent) file:
options snd-hda-intel model=hp
Posted on Nov 07, 2010
  • 1027 Answers
SOURCE: I need Bluetooth driver
use this page:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3935158&taskId=135&prodTypeId=321957&prodSeriesId=3935157&lang=en&cc=us
- chose your operating system
- download driver
and good luck!
Posted on Feb 18, 2011
HP proBook 6440b laptop screen is dim on one half than the other half.
hi the problem with your screen is that their is a problem with back light at the other side, the problem either the inverter for back light or the back light itself is busted. as my recommendations if you don't mind if you don't have enough knowledge and tools just leave it to the pro so you can avoid major damage. hope this information can help you.
Aug 05, 2011 | Computers & Internet
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
Evo N600C, display is 'dim' and mainly 'red'
There is one CCFL lamp on the bottom edge of the LCD screen.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 04, 2009 | HP Compaq Evo Notebook N600c
Pavilion dv6600 dimmed lcd monitor
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
var experts = [{ avatar:'/Uploads/Avatars/68F2C5C.jpg',userName:'MNfisherman',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.7%, 799 votes', userUrl:'/users/mnfisherman',solutions:2295,experience:'Experience: Have knowledge with just about anything that is electrical, mechanical, or electronical & more!',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/ABF4CAB.jpg',userName:'localwonder',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'90.7%, 1460 votes', userUrl:'/users/localwonder',solutions:2913,experience:'Experience: I have yrs of experience dealing with many situations.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'avid101',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.8%, 264 votes', userUrl:'/users/avid101',solutions:795,experience:'Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'adirondacktr',"memberSince":'July 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.0%, 108 votes', userUrl:'/users/adirondacktr',solutions:363,experience:'Experience: hands on experience,training, mechanically gifted,and favorite reading material is how to fix things',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/4FD9B30.jpg',userName:'venexcsd',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.2%, 197 votes', userUrl:'/users/venexcsd',solutions:526,experience:'Experience: 50 years in the University of Life, plus an electrical engineering and computer background. ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/579A389.jpg',userName:'benwabnick',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.5%, 383 votes', userUrl:'/users/benwabnick',solutions:881,experience:'Experience: Been working as a computer technician for 10 years and have certifications in A+, Network+ and MCP',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'justaskjoe',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.8%, 964 votes', userUrl:'/users/justaskjoe',solutions:1787,experience:'Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/5446F1F.jpg',userName:'heavymetal77',"memberSince":'June 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.2%, 95 votes', userUrl:'/users/heavymetal77',solutions:311,experience:'Experience: I have a wide range of experience in many fields.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/1B34289.jpg',userName:'taran_2005',"memberSince":'November 2008',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.9%, 392 votes', userUrl:'/users/taran_2005',solutions:1752,experience:'Experience: If you have the desire to repair, follow my steps and be happy!!!! ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/0915BCA.jpg',userName:'komguy',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.0%, 177 votes', userUrl:'/users/komguy',solutions:301,experience:'Experience: I have been a Canon certified warranty repairman for 4 years. Always on top 10 national list.',brandType:0,brandName:'',brandIcon:'' }] BRAND_ICONS_DIRECTORY = '/images/Brands_24x20/{0}.gif'; var ctrl_experts = new Fixya.TopExperts(experts,$('ancAvatar'),$('imgAvatar'),$('ancUserName'),$('spnMemberSince'),$('imgRank'),$('spnRank'),$('spnRating'),$('spnSolutions'),$('spnExperience'),$('imgPrev'),$('imgNext'),$('imgBadge'),$('spnBrand'),$('ancRating'),$('ancSolutons')); ctrl_experts.render();
Jul 09, 2009 | HP Computers & Internet
Can not see anything on the screen
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 28, 2009 | HP Pavilion dv9700t Notebook PC
No light from my replaced display
Mar 28, 2009 | HP Pavilion dv5000t Notebook
HP Pavilion dv1000 Notebook PC display not coming on
Does the laptop power up even though you can't see an image on the screen?
Connect an external monitor to your laptop and powe it up, if you see the normal Windows images then the laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | HP Pavilion dv6000t Notebook
HP dv9000 won't come out of black screen.
You could have a faulty video card, or a faulty inverter, (this supplies high voltage to the CCFL lamp), or a faulty CCFL lamp.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Mar 19, 2009 | HP Pavilion dv6000z Notebook
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
44 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
