Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP - After sometime the screen switches off
Hi, My Dell flat screen monitor, E173FP, is about 1 year old. For the past 2 weeks, when it is running for say 30-60 minutes, I notice the screen momentarily brightens up and within a second after that it switches off even though the computer is still running. The power switch still shows power in it. If I switch-off and then switch it on from the monitor's power button, the picture re-appears but goes off again within a few seconds. This situation of picture off-power off-power on-picture on-picture off can repeat itself many times. Once it starts, it makes the working on PC impossible thereafter. It happens irrespective of whether I am on internet or working on any local application. Any solutions?
  • Anonymous May 07, 2009
    I have the same problem with my Dell 3008WFP. Dell have replaced it 3 times, but within a couple of days the problem starts again - the screen flickers very brightly for about a second then shuts down. The blue light indicates that the power is still on - I have to switch it off and on again to get the screen to work again..
Sounds like the power inverters went out on alot of these dell flat panels...dell should make it right with these customers i think it is faulty hardware or design
Posted on Jul 03, 2007
Mine does this too...honestly if you hit the back of the monitor with some force it will clear up... It sucks but it works for my Dell monitor.
Posted on May 17, 2007
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Posted on Sep 02, 2006
I have a Dell E173FP 17 inch Flat Panel LCD Monitor. About two weeks ago after having turned it off at night (leaving the PC on) then turning the monitor back on in the morning it would light up to half of...
The monitor can be repaired - by replacing one or both the fluorescent tube and inverter. You can have the work done for you - or you can attempt it yourself. Lamp prices vary based on size - but most hover in the $10 range. Inverters can vary in price too - but run more than lamps for the most part. There are numerous suppliers for these parts such as this and instructions about how to do it such as this.
I hope this helps! Please rate my reply - thanks!
Dec 21, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
Dell flat screen monitor does not come on after
Sounds like a capacitor on the power strip inside the monitor is failing.
The cost to repair can run $400.00. A tv repair shop may be able to fix it, but most technicians recommend buying a new monitor.
However, if you are experienced in electronics, you can disassemble the monitor and replace the capacitor. Radio Shack sells them for between $15 to $20.
Oct 10, 2009 | Dell E173FP 17" LCD Monitor
White screen on monitor
o cant suggest anything appart from buying a new one sorry.
please rate my help to you.
thank you
Apr 22, 2009 | Dell E173FP 17" LCD Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Replacements for lighting inside monitor
Measure the length of your screen or the old tube and get these from ccfldirect.com or moniserv.com . measure the diameter from the old tube, Just be close. Good luck!
Jan 16, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
hi, check out the micro switches on the monitor.. let me know..
Nov 17, 2007 | Dell E173FP 17" LCD Monitor
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Oct 01, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
371 people viewed this question
Alun Cox
