Question about Linksys Wireless-G WRT54G Router
My linksys router will not connect to the internet
I have connected all the proper cables and unplugged from the wall and replugged restarted computer several times and I can not get the router to send the IP address to the computer. I thought it was my router, I hooked a newer one up and it doesn't work either, so it's not my router it's in the connection somewhere. Last month we had hurricane Ike go thru here and it took down the internet line. So, when we got that back up suddenly the router would no longer work. I have been trying to figure it out on my own by reconnecting, unplugging all that ! Now I am frustrated and don't know what to do next. I can't get the IP address screen to continue on with the setup. Now if this heps, I have run all the network Diagnostics and this was found. No, HTTP, HTTPS, FTP connectivity. And I do have them enabled in the security section of internet options. Please help.
    Novelist:
  • 173 Answers
Reset your rourter, with a pin or a paper clip for 30 seconds and disconnect power and wait for 30 seconds and reconnect it back and check if the power light is lit up in your router first..if yes, connect the modem cable out to the wan port of your router, and check if the wan light is lit up in your router, if yes connect a lan cable from the number 1 lan port of the router to the desktop pc and check if the lan 1 light is light up if yes the router is working properly, then check for the ipaddress in your desktop..if not your router might have gone bad..if you have any doubts rever back..
Posted on Oct 23, 2008
I have used the Linksys CD to setup my wireless connection to e1000 wireless router; in diagnostics, I discover that I am connected to the router but not to the internet. I also try setting up ethernet to...
Make sure the Modem is plugged into the correct port on the E1000 (far left port labelled 'internet' on a yellow background). Unplug all the devices power cables and restart them in order from the wall (modem - router - PC/MAC) make sure the modem has link and activity lights flashing, if there is a light for 'internet' wait for it to be on before plugging in the router. You might want to call your ISP and confirm theres nothing funky with the line/modem.
Aug 22, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
My problem is that on my daughters computer it says connected with limited access. yet on the main computer where the modum is placed the internet works fine. my daughter has claimed she did not do...
Hello
Try to reboot the router.
1 shut down all pcs connected to router.
2 Unplug all cables from router,mark them if you think you will forget.
3 Unplug power from router also.
4 In the back of the router there is a small reset button hold this in for 1 min with a pen tip or a paperclip.
5 Replug everything back into router,power up router.
6 restart your pcs.
Nov 29, 2010 | Linksys Wireless-G WRT54G Router
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Desktop will not connect to internet when router is connected unplug and go through modem will connect linksys program that came with router will not recognize the router when you setup, worked for over 2...
Each network adapter (in the Linksys router, or in your computer) has a unique 12-character code. Some ISPs (Internet Service Providers) will require you to "register" this 'MAC' (Media Acquisition Control) address, before they grant an IP-address to the device (router or computer). So, when you "bypass" the router, you're showing a different MAC-address to the ISP, and they are not allowing that MAC-address to get connected. Talk to your ISP.
Or, some cable-modems check the MAC-address, allowing just one or two computers to connect. Turn the cable-modem off, to make it "forget" the MAC-addresses that have connected to it.
Connect the router to the cable-modem.
Turn the modem on.
Turn the router on.
Connect your computer to the router.
Restart your computer.
Or, maybe the router really is "dead'; try the above, before choosing this option, and before buying a new router.
Jul 21, 2010 | Linksys Wireless-G WRT54GS Router...
I can't get my router to connect to the phone jack
Connect ethernet lan cable to computer and router end.
In router there is LAN port connect lan cable to that port and connect other end of that cable to your computer ethenet lan card.
Then connect phone line jack to router's ADSL Port.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Linksys Wireless-G WRT54G Router
I have to unplug and replug the router to get online
If you connect the computer directly to the modem
does it work properly.
If that works properly then your modem is working
properly.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with
the cable.
If not then you will need to connect the computer
to the router.
Download the firmware of the router from the
manufacturer's website.
enter the model number. select proper version
number and download the firmware of the router.
Once you download the firmware, you will need to
open the router set up and upgrade the firmware of
the router.
After upgrading the firmware, it is recommended
that you reset and reconfigure the router.
Click Here for more information about router and
networking
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Setting up Comcast High Speed Internet with a Linksys Router
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. - *Note: If you are still unable to get on to the internet please repeat from step 1.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
The following article will describe how to setup Comcast High Speed Internet with a Linksys Router: Connecting your cable modem to the Router 1. First connect directly to your Cable modem without the router and verify that you can get on line. 2. Once you've verified that you can get onto the internet without the router please proceed. If you can not please contact your ISP for further assistance. 3. Now unplug the Ethernet cable that connects to your DSL modem from the back of your computer. 4. Take the connection that you just unplugged from the back of your computer and connect it to the WAN port of the router. 5. Take a different Ethernet cable and plug it into port closest to the WAN port, or into the LAN port. 6. Look on the front of the router. The following lights should be illuminated: - Power - WAN Link - Link/Act (On the port that you connected your computer to) - Note If other lights other than Link/Act are illuminated on this port, that is normal - You may have a few other lights illuminated depending on the model number router you have, but the 3 above must be illuminated for proper connection. 7. Hold the Reset button on the router for 30 seconds or more 8. Restart your computer Checking the MAC address of your Computer Please follow these steps from the computer that was connected directly to the internet with out the router. If you do not, then you may not be able to connect to the internet properly. A. Windows 9x/ME 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in winipcfg and click the OK button 3. When the "IP Configuration comes up" click on the gray box the black arrow and select your Ethernet card. 4. Please make note of the "Adapter Address" B. Windows 2000/NT/XP 1. Click on the Start button and click on the Run option 2. When the "Run" window opens please type in cmd and click the OK button 3. When "Command Prompt" appears type in ipconfig /all 4. Please make note of the "Physical Address" Configuring the Router 1. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 2. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 3. The "Enter Network Password" window will appear. 4. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. By default the router will be set to Obtain an IP Address Automatically. 6. Click on the Advanced tab. 7. Click on the Mac Addr. Clone. 8. When the page loads, input the Adapter/Physical Address you made earlier and input it into the proper fields. 9. Click Apply Finishing the Setup 1. Shut down your PC. 2. Unplug the power from the back of the router. 3. Unplug the power from the modem. 4. Wait for 30 second. 5. Power up the modem. 6. Wait for the lights to stop blinking. 7. Power up the router. 8. Start up your computer. 9. Surf the internet. *Note: If you are still unable to get on to the internet please repeat from step 1.
Feb 16, 2006 | Linksys WRT55AG Router
Linksys Wireless-G WRT54G Router Logo
333 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
