Question about Radio Communications
Why does my v68 icom radio display err-E on lcd
    New Friend:
  • 18 Answers
Replace riibbon cable connected between cpu board and keypad board
Posted on May 14, 2013
2 Suggested Answers
  • 36 Answers
CL-ERR means that the "frequency database" in the radio has somehow become corrupt. You will need another radio to clone from and a cloning cable to clone from good unit to yours, or the programming software and a cable to fix this issue. An Icom radio dealer may be able to do tjhis for you to fix the issue.
Posted on Dec 29, 2007
Display has stripes
This is a typical failure mode for this rig. The only repair is to replace the display. Check with Icom, I think they still stock the proII displays, if not, out of a scrap radio is your only hope
Feb 21, 2014 | Icom IC-756PROII Transceiver 3205669
OVER V error ON ICOM IC-A24 when power UP ?
Sorry to say, but normal. As long as radio works fine otherwise don't worry about the error display.
Nov 30, 2013 | Icom IC-A24 NAV/COM Transceiver
I need the IC-F11/S to talk to my CP100 (vhf) model
Programming the CP100:
Programming the IC-F11:
I believe one must purchase software and a programming cable to program the frequencies of this radio.
Mar 13, 2009 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Chris, How is it that you programmed your radio. Do you have the software for this radio? if so please send me a copy of the saved radio file so that I can make sure that all the settings are correct.
Jul 28, 2008 | ICOM Informatique Icom Radio U16, IC2GAT,...
ICOM IC-A23 CL-ERR Problem
My neighbor just had this problem so I delved into it and fixed it.
You will need another working radio and the cloning cable.
This cable is nothing more than the same one you use to pipe your MP3 player into a car's AUX input.
You either have one or know someone who does that you can borrow.
If not go buy one from Sears ,Best Buy or any decent truck stop should have them for about ten bucks.
Turn both radios off.
Now with the 3.5 mm cable plugged in to both radios hold down the up and down arrow buttons and turn them on.
They should say "clone".
Now press the" ENT" on the good radio,
This will send the data over to the "bad" radio.
Now turn them both off, remove the cloning cable and turn them back on.
Both should be working now.
\WARNING if your battery is in bad shape it can cause the problem to come back. Either deep six the battery or hit the battery for a few seconds with your car battery charger to shock the cells.
Some times this can extend the battery's life.
Good luck!!
Dec 27, 2007 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Icom m402
you may have poor connections on you LCD screen leads. I would first determine if the blinking is being caused by a loose connection or by something happening within the CB circuitry. The best way to do this would be to try to push and hold the LCD screen to stop the blinking if this works then your trouble is a loose connection. If it does not work then you may have some kind of internal problem. One such problem would the the IC driving the LCD screen you will need to have a schematic to troubleshoot this. The schematic will show you the voltage readings that should be on the pins of the LCD driver IC, and by measuring the voltages you should be able to determine which components are defective. You may also want to use a logic probe if the schematic contains a truth table of the states the pins sould be in under test conditions.
Nov 08, 2006 | ICOM Informatique M402S Base CB Radio
Radio Communications Logo
406 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
