Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Xlite softphone + bluetooth headset = static!
I am using xlite softphone on my pc & have purchased a motorola bluetooth usb adapter to use my bluetooth headset for these calls.
I do not experience any problems on my end, but the person on the other end of the call is experiencing extreme static & echoing!
Any resolution tips?
SOURCE: H500 bluetooth headset
Turn down the volume on the PHONE, not the headset. Motorola 325i w/ H500. Again, turn down the volume on the PHONE, not the headset. In my case almost all the way down.
Posted on May 02, 2007
PcExpert
  • 293 Answers
SOURCE: Won't charge!
HEADPHONES AND SPEAKERS Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps =============================================== If you are having trouble with a Newly bought items then return them a demand a replacement or a refund!You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 19, 2007
SOURCE: Broke the ear hook for the Motorola h500 bluetooth headset
The ear hook on my H500 broke as well.  I called Motorola (866-289-6686) and they are mailing me a replacement.  Even though This bluetooth has a 1-year warranty.  I purchased mine in Jan. 2007 and was covered but the rep didn't verify anything regarding the purchase date so even if you're outside of your warranty, you might still give it a shot.
Posted on Oct 10, 2007
SOURCE: Pairing Motorola S9 headset with PC
i have try this before i couldnt do it untill i tryed using the same bluetooth brand as my head phones worked straight away
Posted on Jan 25, 2009
SOURCE: Motorola H9 Bluetooth headset
H9 want come on
Posted on May 09, 2009
How do i fix the static on my bluetooth headset
Well yea but what if it doesnt have a volume control...my model is a quikcell BOLT mini auricular headset
Jul 22, 2010 | Motorola Mobility Q Bluetooth Headset...
I could not install driver in vista
It is suppose to be plug and play. Vista advantage is you need not install drivers for most if not all external hardwares.
Try letting the system locate the phone itself.
Rate this please.
Apr 06, 2009 | Motorola Mobility PC850 Bluetooth Wireless...
I have Motorola H500 headset and don't know how to use it with my PC
Unless your computer is already bluetooth enabled (many PC's aren't), you'll need to also purchase a USB Bluetooth adapter. Amazon often sells the two units in a single package.
Apr 04, 2009 | Motorola Mobility Universal Bluetooth...
Can't figure out how to connect mini-usb device via bluetooth to
find motorola user guide it at
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/W377g_UG_.pdf
this is for w376 and w377 user guide
Mar 24, 2009 | Motorola Cell Phones
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Jan 25, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Jabra BT620 Microphone dose not work with Soft Phone on My PC
Well, I got the same problem the days before, and after some trying, I've solved.
I'm using the Toshiba bluetooth adapter, too. You see, when you want to make a new connection with your bluetooth device, you may either use the Express Mode or the Custom Mode. Go with the Custom Mode, then, there appears the Jabra BT620. After input the 0000 code, you may select the services from 3 options. There, you can find the headset or hands-free option.
Go with that, than you may have your Jabra BT620 as a microphone!
Sep 09, 2008 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Bluetooth
Here's the user manual online.
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H375%20Bluetooth%20Headset%20QSG.pdf
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
445 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
