Question about HP Office Equipment & Supplies
My HP CM1312nfi is printing a line on the left side of any documents that I copy? Any suggestions as to how I can stop this please?
  • HP Master
  • 1,684 Answers
This is usually caused by ink or correction fluid on the scanner glass. Here is a link to an article about where to look and clean to clear the lines on copied and scanner pages.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, If so please rate my solution.
BuddyMc
Posted on Feb 10, 2012
2 Suggested Answers
  • 223 Answers
SOURCE: my HP Printer a CM1312nfi mfp printer is printing
It could be one of a few things, one being the yellow toner cartridge, try using a different cartridge after replacing the cartridge run several cleaning modes from the service menu. If the problem is still persistent it could be the fuser assembly is too hot and therefore is scorching the paper or the etb is dirty. to clean the belt, access the secondary service menu, setup/press setup and cancel at the same time/ press set up again and you should see the secondary service menu/ select clean belt/ do this 5 times.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
Hp laserjet m1522nf is copying 3inch vertical line in left side of the page and otherwise page is very very clear
If your printed documents are clear then you need to clean small glass which is on left side from big glass. this glass is used for copying from ADF.
Otherwise it is faulty toner cartridge.
May 12, 2016 | HP Office Equipment & Supplies
My HP Printer a CM1312nfi mfp printer is printing a yellow line down the left side of my document
Al
May 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
57 people viewed this question
Seeker5211
Seeker5211
