Question about Microwave Ovens
Need to replace turntable drive motor. g.e. model jvm1533wd002
  • Microwave Ovens Master
  • 8,871 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 24, 2008
Food Heats fine, but turntable wont rotate. Makes a loud noise until we press the
see this tips for to repair:
Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Sep 09, 2012 | GE JVM1860 Microwave Oven
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Turntable stopped turning one day last week. Will turn slowly without glass plate on spindle, but not with any weight. Is there a schematic for turntable drive somewhere?
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $25 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is WB26X10038 (listed as item 43). If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
May 09, 2011 | Hotpoint RVM1425 Microwave Oven
My turntable has stopped functioning and I need to replace the motor I think. Any ideas?
find out first if its a direct drive turntable or a belt driven turntable with motor,w/o a make and model number i cant tell you
Aug 01, 2010 | Microwave Ovens
MODEL W 201 TURNTABLE DOES NOT ROTATE
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
repairclinic.com
If the model number is correct, the part number for a replacement motor is 8183954. If the coupler is stripped and needs replaced, the part number is 8206228. The average price for a motor is about $45. The coupler is less than $10. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jul 19, 2010 | Whirlpool MH7140XF Microwave Oven
My microwave is still working but not rotating, what is wroong with it
There's a turntable motor in the bottom of the oven that drives a turntable support directly in some models, and a plastic coupling that rotates the turntable in others. Turntable motor failure is common, or there could be connections in the power to the motor that have gone bad. Sometimes the plastic of the turntable coupling cracks, and the motor shaft turns but the turntable doesn't.
You can check a turntable motor with an ohmmeter. A good motor will show fairly low resistance (a few hundred ohms or less) between its terminals, while a very high or infinite reading means it's bad. In most models of oven you get at the motor through and access panel on the bottom. Replacement motors for many brands are available, although they're not always easy to find.
It may be more economical to replace the oven if it's a basic counter top model. They are under $50 these days, and a replacement motor might cost $20 or more. Of course, you can continue to use the oven even if the turntable doesn't, you'll just need to turn the food yourself occasionally during cooking.
Hope this helps. Thanks for using Fixya!
Mar 08, 2010 | Microwave Ovens
Turn table doesn't turn. The middle peg doesn't move.
The microwave oven does not have a drive belt for the turntable. The component you describe that the carousel plate sits on its called the turntablel shaft or turntable coupler and it is attached to the turntable motor. This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can usually purchase replacement parts at the any of the following websites:
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Dec 20, 2009 | GE Advantium 120 Convection/Microwave Oven
Turntable has stopped turning
Remove the turntable plate from the oven. Put a cup of water inside the oven, away from the turntable drive gear. Turn the oven on and look through the door to see if the drive gear is turning. If not, then the motor is probably defective and needs to be replaced.
Nov 15, 2009 | Sharp R-303CW Convection / Microwave Oven
Turntable replacement
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you also need to replace the turntable motor or coupler, you will need to remove the bottom panel to access the motor.
Be sure to unplug the oven before removing any screws.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 19, 2008 | Microwave Ovens
The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Oct 17, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
