Went off when drivers door opened. RAC disconnected, and now my husband
cannot find how to connect again. Where is Horn located and where does wire run ?
SOURCE: ford 1993 probe horn
The horn Button at the steering wheel is simply a switch. It grounds out when pushed causing the circuit to close, routing it though the actual horn under the hood which is sitting there waiting to activate.
SOURCE: Where is the DPFE Sensor located on a 2003 Ford
That is the (Differential Pressure Feedback Exhaust) - e.g. EGR Valve. You shouldn't have any trouble finding it. There is usually a metal tube from the exhaust manifold going to it,as well as one or two vacuum hoses.
It has to also, direct exhaust gas into the intake,so there is your key.
SOURCE: Horn went off when no
The horn contact is embedded in the outer horn pad
The change in the climate eventually shrinks the pad and the horn will go off by itself
Replace the horn pad is all that can be done
