Question about Microwave Ovens
MY MICROWAVE OVEN WORKS AS NORMAL EXCEPT FOR THE TURNTABLE; IT DOES NOT REVOLVE AT ALL
  • Microwave Ovens Master
  • 9,086 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
There may be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If not, please reply back with your correct brand and model.
Posted on Oct 24, 2008
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
Why do I hear a popping noise when turntable revolves counterclockwise.
If the turn table automatically picks up the tone arm and starts the record and changes after the record is over, then you are haering the gear box.
Feb 23, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Oven seems to be working with the exception of the turntable not revolving
Check that there is no damage to the plastic turntable rotor (i.e the part with wheels) underside the plate. Motor could be working but rotor missing or not connected properly, or damaged. Otherwise the turntable motor or motor driver circuit is fried.
Feb 04, 2015 | Microwave Ovens
Can you trun off the turntable
Hello paula.... there is no switch or other easy way to turn off the turntable. What you can do is simply remove the glass revolving tray and ring and use the microwave with the turntable removed. Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Sunbeam SMW777 Microwave Oven
Food not being heated although control panel works and turntable revolves
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 15, 2010 | Baumatic BTM231SS Microwave Oven
Not heating or defrosting although light works, timer etc works
heatman101
fjfh
May 11, 2010 | Neff H5470 Microwave Oven
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Turntable doesn't spin
Well the table might not be on the revolving piece- that is what happened to my microwave oven, or the revolving piece might have to be connected to a belt inside that turns it
Jan 17, 2009 | Sanyo Microwave Microwave Oven
Noisey turntable
try pulling on the plastic drive and inspect it you just pull up on it to remove it
Jan 30, 2008 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
