Question about LG VX6000
"Car Kit" Im having problumes with my phone. When it is not connected to the charger it comes up with red writing on the main scree and says "CAR KIT" I have looked through all the settings and cant change the settings. I cant hear any sound on the phone and when i dial a number i cant hear anything or when someone calls me after i pick up i still cant hear anything. The only way it comes off car kit is when its on charger and i can hear all the sounds and make/recieve phone calls Also whenever i close my phone to hard it just switches itselve off. please help!
    New Friend:
  • 163 Answers
This model do that when it get wet if that the case there is nothing to do but chage the board, go to the celu store they have jonk to fix these for about $25.00 more or less..good luck
Posted on Aug 06, 2006
My phone has no sound, and it now says "-Car Kit-" WHY?
Firstly i come to your 2nd question where you asked what the meaning of Car Kit. Bro Car Kit means a sound system which contain also blue tooth, DVD, FM etc. So in Car Kit any one can pair their blue tooth devices i mean your cell phone where blue tooth are available. So when you pair your device at the define range then Car Kit will be connected with your phone so when your receive or dial a call then the Car kit speaker will be active automatically. You can hear voice from there.
Now come to your next question,
If your Car is off or you are so far from car then your speaker will be enable normally but if it don't work then means your speaker disable or inactive. As a result, you have to change your speaker by a expert technician then you will release from this problem. Thanks a lot
Nov 09, 2012 | Cell Phones
Parrot ls3200 displaying goodbye
Good bye appear when the car kit switch off. Then suppose to be in relation with the question of the 12 ignition. If it doesn't disconnect of switch off in relation with the car, maybe the kit has a 12 DC and not an ignition connected.
If you can disconnect the power supply of the kit, just do it, and it should normally coming back to the main screen.
Mar 20, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
HOW DO I CONNECT MY NEXXUS HANDS FREE CAR KIT TO MY MOBILE
I bought both the Nexxus Drivespeech Pro and the Drivetalk Pro, one each for my girlfriend and myself. The drivespeech comes with an in-car charger and separate USB cable. The drivetalk comes with a wired in-car charger. Can I charge the drivetalk using only the USB cable through a computer?
Dec 13, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Getting an error that says car kit on phone
Mine said car kit and I kept reading it was because it got wet, and my phone didn't get wet. I noticed a little corrosion where I plug the phone in starting to form and I rubbed a little off and the car kit on the main screen went away.
Sep 08, 2008 | LG Cell Phones
Vx8300 stuck in car kit
I just ran into this problem myself (besides that fucked up white main screen i have). So after reading all these other solutions i played with the thing and found that its one of the right-most pins in the charging port. Probabily a pin touching the metal housing or another pin completes the same electrical circuit used to determine if a car kit is hooked in. I figured this one by shoving a knife through the opening to clear out any debris and every-swipe made the "car kit" banner dissappear. so check for pins touching something it shouldn't. ( i said F-it and ripped that pin out!)
Hope this helps more
Jan 05, 2008 | LG VX8300 Cellular Phone
Car charger
'Charger time" in the car kit menu means when it's plugged into a car charger, it's only going to "stay on " and charge for 3 hrs max or whatever you set it to.
It's useless for newer cars as newer cars don't continue to keep power flowing to the power ports when the car is off. it's more for older model cars.
Dec 19, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Car kit
same problem....i found a neat solution to this one..see if it works for you too...i simply charged my phone as much as possible, drove to a nearby lake(you should do this while its light outside for best effect's to be noticed), and then i THROUGH the damn thing as farrrrr as possible..be sure that you spend the time so as to take it all in..then, go to your nearest retailer and get any new phone that does not say LG on the front...it worked for me and i'm glad to say that it definetly decreased any homicidile thoughts i had been having due to the issue.
Nov 02, 2007 | LG VX8300 Cellular Phone
Cell Phone LG VX3450
Well from my experiences, and I manage a wireless store, you have gotten the phone wet in someway. It could have been anything from just sitting in the sun or being in the bathroom when you take a shower. You may try putting the phone in a bag of white rice for 8 hours or so and that could make it come out of car kit.
Jun 18, 2007 | LG VX3450 Cellular Phone
Car kit
there is internal damage an easy fix is to plug it into the car charger and it will only work on the charger you should have let the phone sit out and dry with the battery detatched. my phone did the same thing about 3 months ago. if that doesn't work you'll need a new phone
Feb 23, 2007 | LG VERIZON VX5200 Hands-Free Headset...
Open Questions:
LG VX6000 Logo
125 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
