Cannot read or format compatible discs on DVR/Player, multiformat
Had my device from new(May 2006). The device has been working ok, until recently,-then, when I insert various compatible disks, it takes an age to "read" then flag says, "cannot read this disk-please check disk", or, if disc is "read", and i try to format it, "cannot format this disc". When dubbing is attempted (if i get that far) "cannot dub with this disc". Have tried all new and used discs, that caused no trouble before. Have cleaned with cleaner-disc & rest device,etc-all according to manual. Whats next! Have been unable to contact manufacturer (JVC) but enough said there! Help!!
  • smsjbh Feb 06, 2009
    will not play dvd's says incompatible disk
  • Anonymous Feb 24, 2009
    can not read disk
    New Friend:
  • 53 Answers
Change the lens
Posted on Apr 20, 2017
  • 6 Answers
SOURCE: How to record or dubbing from VCR To DVD
possibly because you are jewish
Posted on Mar 19, 2008
  • 476 Answers
SOURCE: PHILIPS DVD/VCR Player Direct Dubbing
No. This unit is a video recorder & DVD player only.
Posted on Jun 10, 2008
SOURCE: LG RH265 - Problem when trying to register blank disk/dubbing
The DVD needs to initialise the disk first. Come out of the HDD dubbing menu and press DVD on the remote. The blank recordable disk should be recognised and you should see Initialise disk? on the screen. Press Start and hey presto, you can now dub from the HDD Movie dubbing menu (as per the manual instructions).
Posted on Dec 01, 2008
  • 4 Answers
SOURCE: can't dubbing because it is stuck on DV/D8 Dubbing, need change
I had this problem too. I had to go to the -R.
Posted on Aug 03, 2009
SOURCE: LG DVD/VCR Recorder Combo RC195 will not finalize DVD after dubbing
It seems that it won't finalise because the disc is full. If you stop before the "Disk is Full" warning at two hours you should be able finalise, but, the disk still won't be recognised. DVD+R seems to work OK.
Personally with LG, Life's NOT Good.
Posted on Dec 13, 2009
How do I fix the DVD player when it keeps reading "Bad Disc" on the LCD?
check that the disc used is formatted right firstly and is compatible with the dvd unit.
May 24, 2014 | 2006 Ford Expedition Eddie Bauer
How to program my urc 4220 remote
Direct code setup for easy device programming
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, aMotorola cable
box, and an RCAVCR.To control devices other than the default brands,performthe
following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control.
[^] For future reference,write down each working device
Sep 06, 2011 | Televison & Video
My dvd player ejects the cd when i load it
Either the reading head on the laser is dirty or bad and it is not recognizing the CD. If it is a homemade CD there might be a formatting problem that is not compatible with your player
Apr 17, 2011 | Televison & Video
Why do dvd players say no disc when there is one in it?
This can be caused by several different things. It may be the read head assembly needs to be cleaned, the disc cannot be recognized. Or it could be a disc format which the player does not work with. Check the owner's manual for compatible disc formats. the Disc may be damaged or needs to be cleaned. The disc may need to be finalized by the recorder it was recorded on if a recordable disc. This is not the case for DVD-video as these are stamped discs.
You can try a cleaning disc but it may not solve the problem.
Inspect and clean the disc and try again.
Having the disc head assembly cleaned may be the answer but the service cost could be more than just buying a new player.
Mar 04, 2011 | Cyberhome CH-DVD 300 DVD Player
After burning my DVD-R, I can not play it on my computor or any other DVD player. What am I doing wrong?
Did you finalize the disc? How you do this will depend on whether you are using your computer or a standalone DVR. On XP, I had to tell my burning software to finalize the disc after burning. On Windows 7, I find it will finalize the disc on eject (until I changed that setting). Finalizing the disc is an option under right clicking when I have a disc in the drive.
On a standalone DVR, you should find an option to finalize the disc in the menus that let you write a title to the disc.
Without finalization, other dvd players will not be able to read the disc. You also need to make sure that the disc is compatible with each player (+/- R is not universal).
I hope this helps.
CIndy Wells
Dec 09, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
DVD plays OK on computer but not on Sony DVD player
It must not be compatible with you player.
Refer to your manual.
Oct 12, 2009 | Sony Televison & Video
Pioneer dvr3100
hi.. the problem is not with ur DVD-RW disc... Its in ur device.Might be the device is unable to read the disc.. so better try to clean up the lense of ur device with the help of lense cleaner... it will remove of the dust so that it will be able to read the disc...
thank u
Feb 01, 2009 | Pioneer DVR 105 DVD-RW Burner
DVR 1600
Start by checking the DVR format compatibility list, see if the dvd format matches. The check DVR settings for playing features that can be adjusted. Try other DVD's that have worked on your DVR previously.
Jan 10, 2008 | Cyberhome DVD Recorder - DVR1600
Formatting New Disc Problems
Dec 28, 2007 | Cyberhome DVR 1600 DVD Recorder
My DVR-111D can't read some DVD's - and they aren't scratched
in your system device settings, specify the location of your dvr111d for it to be able to read those disk.
Dec 28, 2006 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
