Question about Evesham Computers & Internet
Cannot locate access to memory slots in order to upgrade RAM on Evesham Voyager 64 laptop.
  • eironald Oct 23, 2008
    sadly evesham have been in the hands of the receivers for over 12 months now, thus no more tech support... i've had the laptop for 5 years now.
    Anyone who might have a manual for this machine, or know how to physically locate the RAM modules would be a great help!
    Thanks
  • 749 Answers
The Voyager would have been even faster with more than the supplied 512MB of memory - you can't upgrade this yourself, but Evesham will supply 1GB as standard for an extra £89.
http://www.evesham.com with the limmitted memory capacity, i would definitely turn off all unused open programs and services you dont need in windows. you may do this and realize you don't need more memory.
Posted on Oct 23, 2008
How do I access the second ram slot on a Voyager 5815-2.5 ?
If it is not in the back where the first ram slot is located, then it is either under the keyboard or on either side under the plamrest. You'll have to remove the keyboard and palmrest to get to it.
Mar 23, 2012 | Evesham Voyager 5800 Notebook
What is maximum ram i can install in Asus U50F laptop and what kind
Asus U50F has 2 memory slots (204-pin SODIMM).
Each memory slot can hold DDR3 PC3-8500, DDR3 PC3-10600 with a maximum of 4GB per slot
for a total of 8 GB ram.
Mar 05, 2011 | ASUS U50F Notebook
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
I wanted to upgrade the memory from 1Gb(in two 500mb slots) to 2Gb so purchased 1Gb Crucial memory. If I put the additional memory in one of the two purple slots computer will not work. If I replace one of...
how may slots do you have??
if @ slots are there then convert your ram or replace it with 2 Gb and the 1 Gb othr......or make the 500 Mb convert it by ur dealer to 1 Gb whole...
Feb 15, 2010 | Evesham Axis 64 3200+ Choice...
Finding RAM slot on an Evesham Voyager 5715 laptop
Laptop ram is always very small, and well protected.
If you open your case, there might be a little "door" or panel to where the ram might be behind.
Nov 29, 2009 | Computers & Internet
Incorrect RAM reported on BIOS
4GB RAM requires a 64 bit compatible processor AND Operating System to be able to access
addresses in memory that exceed the 32 bit assress space.
I'm not familiar with the motherboard that you are using but simply expanding RAM isn't enough if your
system isn't 64 bit compliant. Assuming it is, then ensure that you are using a 64 bit version of Windows 7 opposed to a 32 bit release candidate.
May 22, 2009 | Acer Computers & Internet
I can't find the second ram slot
Lots of laptops have the second slot under the keyboard. If you are adventurous take the keyboard off and look in there.
Mar 11, 2009 | Evesham Computers & Internet
Position of memory modules
Hi there
There isn't a third DIMM slot its attached to the motherboard and cannot be removed, replace the 256 memory modules, thats all you can do
kind regards and please don't forget to rate us
Dec 13, 2008 | Evesham Voyager 6200 Notebook
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Computers & Internet Logo
96 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
