Question about Samsung LN-T4065F Television
Strobing all works good but the flashing
Sound workes pix still their just strobing
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Vizio screen flashing
ok when mine did that i shut it off then on then off then on again four times then unpluged it and plugged it back in and waited for a few minutes and it was fine if that don't work then its most likely an internal problem and it would have to be fixed by a professional
Feb 05, 2014 | Televison & Video
I have a Canon Powershot SX10IS. My flash is set "On" but will not go off and allow me to take a photo. Can flashes "Burn out?" If so, can I get a replacement?
Hi,if you set the flash on and still not working, your strobe unit is damage and need to be replace.bring to service center and for sure there's a replacement parts for your camera. Strobe unit compose of capacitor and once the said parts is damage the flash will not work anymore.
good luck and thank yo
Aug 10, 2010 | Canon PowerShot SX10 IS Digital Camera
My flash don't work at all when i turn it on a
1.if you can open and reset the connection of your strobe unit of flash unit inside.
2.the strobe unit or the capacitor of your flash need to replace.
3.need to rbing to service center
Jun 03, 2010 | Olympus FE-46 Digital Camera
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
When i try to use flash it just says strobe charge
Before the flash can work, the strobe have to be charged. as soon as that is done it well say ready.
Feb 02, 2010 | Aiptek ISDV2.4 Flash Media Camcorder
I can't get flash to work on my camera
Make sure you have good strong batteries. "Strobe Charge" is what the camera says when it's sending power to the strobes that make the flash. It can take alot of juice and if you're using weak or old batteries they may not be able to handle the load. I found with my DSLR that the Energizer Lithium batteries are great for cameras and have been using those exclusively in all my cameras. I just got the Aiptek about a month ago, have not changed batteries yet. My other digital video camera ran for over two months on one set of them, and I used it alot. It's on it's second set now and my husband has it.
Feb 10, 2009 | Aiptek ISDV2.4 Flash Media Camcorder
I just got a new phone and activated it at us cellular and now my incoming picture text messages fail and say network authentication failled but i called and i do have unlimited text messaging and free...
Alot of the newly activated phones require that you wait 24 hours before you can call. If you try and make calls and it doesn't work, this could be why. The same applies for text messaging.
Good Luck!
Feb 01, 2009 | Kyocera Strobe K612B Cellular Phone
580ex not flashing at all
after using it many flashes at 1/1 power the strobe doesn't work anymore
Jun 19, 2007 | Canon SPEEDLITE 580EX TTL Flash
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
