Question about Radio Communications
I have a cobra 29 nw ltd classic when keyed it will show on other radios but they cannot here what im saying. we have tried other mics but it does the same thing.
  • bub7513
    bub7513 Feb 10, 2012
    Im running a wilson 5000 62" whip magnet mount so I know its not a junk antenna. I set the swr and all that. The radio has mosfet finals and has been peaked and tuned.
  • bub7513
    Checked loose connections etc stil same problem
3 Suggested Answers
Dodgem250
  • 68 Answers
SOURCE: Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
Posted on May 10, 2008
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
Posted on Apr 24, 2009
Cobra 29 now Ltd classic Cobra 29 nw.ltd classic receives not well but does not transmit don't even move the swr./power meter any ideas
High SWR on antenna system.. may have mess up your RF final transistors. if you were talking on it for a long time. have someone check the SWR on the antenna system... should be a FREE service.
Jul 13, 2014 | Radio Communications
When i try to calibrate my cobra 29 ltd classic the needle will not go to the right
make sure you have your radio set on CAL and then adjust the knob that says adjust .Turn it all the to the right then bring it back to the set point on the dial then un key the mic,move the switch to SWR , key the mic and that is your reading. Do this on channels 40 - 1 then 19. Make sure you write down the readings for each channel. The adjust your antenna from there.
Jul 05, 2014 | Cobra 29 LTD CB Radio
How to fix the dimmer light ona cobra 29 nw ltd classic
HI I AM TRYING TO FIX MY 29 COBRA LTD IT WENT OUT ON ME
Feb 04, 2011 | Cobra 29 LTD CB Radio
29 nw LTD no audio on receive out the speaker in the radio or through the ext speaker and on transmit no audio.Radio shows a 4 watt dead key
If you take your external speaker and plug it into your PA jack in the back and key up your mic do you hear anything. If so then its not your IC chip if not its your IC chip and it will need to be replaced.
May 14, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Radio stays transmiting after mic released
What happens if you "key up" and "let off" and the transmitter "hangs", you remove the microphone plug from the Cobra ?
Will it still be transmitting or will it stop ?
If it stops, the problem is in the microphone with a "hanging" switch which you can easily clean or replace.
Iif it keeps transmitting while the mike is disconnected, there is a problem with the Rx/Tx switching circuit. This needs further investigation by use of a circuit diagram.
Feb 13, 2009 | Cobra 29 LTD CB Radio
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
COBRA 29 NW LTD CLASSIC
Capacitor C-82, which connects the output of the driver to the input og the final, is leaky or shorted, putting +12 volts on the base of the final, which blows it immediately.
Mar 28, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
29 help
hi, sounds like you have a problem with the SWR' S Probably too high. Tumbleweed01
Mar 12, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
29 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
