Technics SA-DX830 5.1 receiver One channel stopped working,Right centre speaker (speaker A) has no sound only a heasing noise... open the unit and found a small piece of speaker wire stuck... was it possible to create a short??? All other 4.1 speakers work perfect. Did test the spekers and its for sure the receiver.
  • 125 Answers
SOURCE: Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Posted on Apr 09, 2008
SOURCE: left channel not working
Thanks, yesterday i tried changing the speakers from right to left, the problem still remained on the speaker getting connected to the right channel. Later i pulled out the speaker wires from the reciver's end for the right channel, cut them and pulled out new strings from the insulation, twisted them and inserted, the speaker is working fine, though not 100% but close to left channel. I guess the problem was old strings in the wire which had got over twisted and were not parallel to each other.
regards
Swamy
Posted on Oct 01, 2008
  • 4234 Answers
SOURCE: Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Posted on Feb 18, 2009
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
Why is my centre speaker not working on my stereo setting on phono?
Records are binaural only. There are only two channels of information, left and right. There is no signal available for a center channel.
Aug 29, 2014 | Technics SA-AX730 Receiver
Technics SA-AX530 all modes not working - no sound
Not a good sign. There should be a click a few seconds after you turn on the unit. That says the output section is OK. If there is no click, you need repair. Perhaps only some fuses inside, but it could be worse.
Also make sure that the speaker switch is in the right position, like A, not A+B. Also the headphone jack can silence the speaker.
Make sure that ALL switches are in the right position.
Dec 17, 2013 | Technics SA-AX530 Receiver
No sound from left channel on my Technics SA-R 230
May just be bad connections on the speaker relay. Flip the main board over, and check those connections. It is pretty common on these older models.
Jan 18, 2013 | Technics Audio Players & Recorders
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
check inside to see if you have a blown fuse on the left channel
May 27, 2009 | Technics Audio Players & Recorders
Surround sound very quiet - technics amp receiver
darn, that was one of the best receivers ever built for the money! all the new receivers these days have 7.1. i would rather have more power in only 5 channels. puppy **** and electronics just don't mix do they? here is the link to get a new one if you like: http://www.google.com/products/catalog?q=SA-DX940&oe=utf-8&hl=en&cid=9395541207809312385&sa=title#ps-sellers
Feb 28, 2009 | Technics SA-DX940
Apr 09, 2008 | Audio Players & Recorders
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
184 people viewed this question
 Grubhead
Grubhead
